Question about Kitchen Ranges
Refrigerator & Frrezer doesn't cool properly - Kitchen Ranges
  • Kitchen Ranges Master
  • 17,129 Answers
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Posted on Mar 13, 2011
Freezer working fine but fridge not cold
The usual problem whena refrigerator doesn't work while the freezer does is a defrost system failure,Do you see a bunch of frost built up on the back wall of the frrezer??
With out a brand or model number i can not be specific but am posting a link to what to check in general when a refrigerator does not defrost automatically.
http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Oct 15, 2011 | Refrigerators
We inadvertently left the freezer door slightly open the frrezer ran continuusly for twenty four hours. Would this cause the condenser to frreze up and burn out? The frrezer is still cold and we...
leaving your freezer door open does nothing ,but work the freezer harder,,,it wont cause no of the prolems you stated,,it will cause your electric bill to rise ,,your ok...the condenser is part of the seal system and it exspell the heat usally under the fridge...good luck
Sep 03, 2011 | Kenmore Top Freezer Refrigerator
Starting this morning frrezer will not drp below 19 degreed and frid is at 48, lowered the temp and still nothing
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | GE Refrigerators
The freezer compartment doesn't work properly.Ice is formed on the back and food won't reach freezing point. ????
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Refrigerators
Excess cooling in fridge, everything seems to be freezing in frreze area (noth the Frrezer)
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 27, 2011 | Refrigerators
Not cooling properly
First thing- set the controls at the mid range of their settings. Next, check the coils under the fridge to see if they are clogged with dust, etc. Next, using a couple stem thermometers, determine the temps in the freezer and fresh food sections. In the fresh food section, place a tall glass of water on a shelf in the middle, put the thermometer in and let it set for awhile in the fridge. Inside the fresh food section, look for the damper opening at the top of the wall in between the two sections. Wet the back of your fingers- can you feel air blowing through the damper opening? Inside the freezer section, look at the back wall- any frost buildup there.
Hope this help.....
Jun 28, 2010 | Magic Chef CTF2125 Top Freezer...
Freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
May 22, 2008 | Frigidaire Refrigerators
Freezer is working, refrigerator side is not cool enough
frrezer ok??? check the ;lower portion of freezer compartment, is ther e a excesssive amount of ice building through th epanel??? if s you have adefrost issue( its not self defrosting)
Apr 02, 2008 | Maytag ZigZagW / B Side by Side...
Indiset Fridge not cooling
If the compressor is running and not cooling then there is no refrigerant circulating in the refrigerator or no air moving across the one or both coils. No ice in the freezer section indicates that no cooling is taking place at all, pointing to a lack of refrigerant rather than poor air circulation due to a bad fan or frozen coil.
You can try a manual defrost to ensure it's not a frozen coil by unplugging the unit for several hours with doors open then starting it again. If there is still no cooling occurring you need to check the refrigerant level. If its low you will have to find and seal the leak, pressure test with nitrogen, evacuate and weigh in the correct amount and type of refrigerant listed on the unit.
Hope this helps, needless to say be sure to find a reputable qualified technician to open and service your refrigerant circuit this will make or break your unit.
Mar 11, 2008 | Refrigerators
Kitchen Ranges Logo
82 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
