Question about Riso Office Equipment & Supplies
We have a gr 3750 and when the paper tray comes up the feed wheels do not start up to feed the paper in.Any suggestions
    New Friend:
    Problem Solver:
  • 5 Answers
  1. check the upward sensor for adjustments and the sensor on the stripper pad unit for adjustments
Posted on Jun 16, 2015
    New Friend:
I had the same problem when I tried to replace the separation pad with a different one. The new one was too thick so Riso thinks it has a paper jam, and there is no error code on the panel for it. Just says clear paper jam and reset.
So you must have a similar problem in the area of the separation pad? It could also be the sensor in that area is bad or out of adjustment. I think it has to be one or the other.
Posted on Dec 04, 2012
  • 132 Answers
The bearings in the paper feed rollers are they facing out and check the paper feed clutch
Posted on Mar 13, 2011
Paper jams when I put it in the tray to fax (from the top tray)
your wheel on one side is impacted with small pieces of paper
this causes the paper flow to go unevenly you need to clean you wheels on both sides oil them and wipe dry with a paper towel
then do the paper feed jam clear and let a few pieces go thru to pick up any remiaining debris
Aug 22, 2012 | Brother MFC-7820N Printer
Samsung ML-2250 the printer is no longer able to feed paper from paper tray. Just spins and doesn't print.
Hi, the only suggestion I could give you is to look where the paper leaves the tray to make sure there are no pieces from a paper jam. Some people even tried using a vacuum cleaner to try cleaning it out.
Other suggestion is to make sure you have the proper paper size selected.
Start, control panel, printers, your printer, printer preferences.
The mechanism that lifts the paper in the In tray up to the paper wheels may either be jammed or broken.
I guess that will help.
Thanks for using fixya...
Oct 28, 2010 | Samsung ML2250 Laser Printer
Having paper jams with my dell 1710 laser printer. Any suggestion?
Hello sir; It depend on where the paper got jam, if jam at the point when paper take off, then you have clean up paper pick up roller or replace it, if jam inside the machine then have to clean up paper feed roller, if jam at the end, check the paper exit senser, make sure it moving freely.
Feb 07, 2010 | Dell 1710 Laser Printer
We use a Lexmark E332n laser printer at work. When someone attempts to print something, the printer jams with a problem with the paper feed coming out of the tray. It essentially folds up on itself and...
try cleaning the feed wheels with a arisole electronic contact cleaner these get a glue composite build up on them and contact cleaner will remove it with out leaving behind any residue and make sure that the paper guides in the tray are not set against the paper to tightly. i have also seen these pick wheels (the rubber tire) be so loose on the shaft that they slip causing this problem.
Nov 19, 2009 | Lexmark E332n Laser Printer
Paper is in the feed tray, but it continues to say NO Paper??? Brother MFC-8460N any suggestions?
Could be a tab or spring broken off of the feed tray, dirty feed roller can cause that error when paper doesn't feed. Paper guide too tight so that paper can't lift to the feed roller also a possibility. Sensor above paper stack out of position.. many possibilities.
Nov 06, 2009 | Brother MFC-8460N All-In-One Printer
Paper not feeding properly, nothing jammed as I have checked. Loading tray having problems.
Check to see if the printer is actively trying to feed the paper. If you hear it trying to feed and see the wheels turning, but the paper won't feed, check to see if a screw securing the feed wheel has come loose. If you hear the sound, but nothing moves to pull the paper in, then you probably have a bad printer. They're too cheap to replace to bother fixing - so get a new one.
May 25, 2009 | HP COLOUR LASERJET CM4730 F MFP Printer
Replaced paper in Omni 3750, now it feeds but doesn't print
Make sure you are using thermal paper and it is feeding from the bottom of the roll. If not press down on the lid when the paper is printing sometmes the tension springs were defective.
Feb 19, 2009 | VeriFone OMNI 3200 (P092-101-10) Printer
Epson cx11nf paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Epson ACULASER CX11NF All-In-One Printer
Sharp AL-800 Paper Feed
Is this something that has been getting worse or just happen at once? If it just appeared it good be something in the paper tray stopping it from liftting or something behind the paper tray or in the paper path of the copier. If it has been slowly happen try to clean the paper pickup rollers with WD-40 and a rag and clean the rubber only. If that works you done, but if it say's to add paper you may have a broken paper present sensor. The jams could also be the paper feed clutch is worn out. Worse case use the bypass tray. Good Luck!!
Feb 07, 2008 | Sharp AL 800 Copier
Paper feed
Feed roller is dirty or worn thin, wipe rubber roller with damp cloth.
Nov 03, 2007 | Kodak EASYSHARE Printer Dock Thermal Photo
245 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
