Question about Hotpoint Washing Machines
Hotpoint wt741 door is locking but locked light not iluminating have changed switch still not working
  • 1294 Answers
SOURCE: hi hotpoint wm62 door locked
Try "end of cycle" button & wait for 2 minutes before you try the door..........
Posted on Jan 13, 2008
  • 1314 Answers
SOURCE: My Hotpoint Aqaurius WD62 door is shuting but the door lock light wont come on!
you may need a switch but not a door see if you can adjust the door and try shutting it hard as front loaders close snug because of the rubber boot check your power too
Posted on Mar 02, 2008
  • 200 Answers
SOURCE: Hotpoint ultima wt741 F11 fault code
HI
There are several reasons why a Hotpoint door could be jammed shut. One of them is the part you describe which is called the ******. With some older Hotpoint models, there is a cable that runs from the door interlock to the motor. When you operate the door catch or button, this part "pecks" down onto the drive belt or the end of the armature's shaft. If the drum is moving, the ****** will slip on the rotating belt or armature and disengage the door interlock. If the drum is not moving, the ****** meets resistance and the door opens. Therefore if the ****** has come off, or is loose, it can stop the door opening. When you attempt to open the door does this part move?
Other things that can stop the door opening are -
  • A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoints - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
  • If there is water still inside the washing machine, then the door wont open either on these Hotpoint washing machines (not on some others though) If this is the case, when you try to open the door the ****** won't try to move down at all. You can open the door usually if you drain the machine. (only applicable with door interlocks that have a rubber pressure hose attached to them)
  • A faulty door interlock
  • The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunge can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thank you
Posted on Dec 06, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint WMA13 door lock fault
If the door locked light is flashing , then the main board probably has a fault on it, due to a problem with the motor, or the board itself being faulty.
Recommend calling an engineer.
Posted on Jan 04, 2009
SOURCE: Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Posted on Jan 22, 2009
HOTPOIT AQUARIUS DOOR LOCK LIGHT FLASHERS
Faulty door interlock easy to fit cost parts about £15
Dec 11, 2014 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint bwm12 door lock light not on, not working!
Try pushing the door in as I suspect the door interlock switch is stuck, if this dosen't work you will have to replace the door interlock switch which can be purchased from Hotpointspares.co.uk and is reasonably easy to fit as can be seen on YouTube .
Oct 24, 2014 | Hotpoint BWM12 Front Load Washer
The door lock light will not come on our hotpoint aquarius WF310 and the machine will not start
Un-plug the machine, remove the spring that hold the door seal look in at the door lock switch, usually it is broken . order the door lock switch for $50.00 MY eBay. p/n 34001265
Jul 26, 2014 | Hotpoint Washing Machines
I have a hotpoint ultima wt741 , 4yrs old , washine machine does not show that the door is closed , the red closed light does not now come on and machine will not start. l have removed top of machine and...
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 03, 2011 | Washing Machines
My door is shut and light is on flashing door on my hotpoint washing machine WT741. the door is shut and it does lock aswel so why the flashing light and no washing being done?
There is likely to be a problem with the 'door closed' sensor/microswitch requiring a service engineer's attention I suggest ;-0(
John C
May 07, 2011 | Hotpoint Aquarius WD63 Front Load...
Hi I have a Hotpoint Ultima WT741 1400 Spin washing machine and I am unable to release the door and belive it is broken. I have rewashed the clothes to check that the door lock was not still on and...
There may be an emergency door release tab inside the pump filter access door.....You probably have a faulty interlock which locks the door during operation and is not releasing...Not a big job for a tech.....Nomess
Apr 09, 2010 | Washing Machines
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WT741 Front Load- unable to open door.
hi julie,
is there an error message on your display?
can you provide me with the complete model #?
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Washing Machines Logo
53 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
