Question about Raypak COMMERCIAL R407A 399K BTU ASME DIGITAL LOW NOx ()
Cuts off before it reaches temp - Raypak COMMERCIAL R407A 399K BTU ASME DIGITAL LOW NOx ()
    Top Expert:
  • Raypak Master
  • 8,686 Answers
Check temp sensor
Posted on May 25, 2016
My '11 Ranger 800 crew overheats. Fan start waits til temperature reaches 215, and cuts off at 205. Why?
The fan is controlled by water temp sensor to keep the temp between 160 (fan off) and 190 (on). Is the temp gauge going into the red? Is the temp sending unit for the gauge correct? The fan will run continuous with A/C on. Also check fan relay for over heating.
May 23, 2017 | Cars & Trucks
Once my dometic av reaches temp Setpoint, it cuts off. Then immediately turns on again, then off again and continues until breaker trips. Is this a thermostat issue or a relay issue?
google it:
  1. Once my dometic av reaches temp Setpoint, it cuts off. Then ...
    www.fixya.com/.../t25789091-once_dometic_av_reaches_temp_setpoint
    1 hour ago - Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric ...
Jul 19, 2015 | Dometic Heating & Cooling
Thermocouple
Does it ever actually reach the temp set? It may just need cleaning and a service so it cuts out at the right temp.
Apr 01, 2014 | Engel Freezers
Temp sensor
You need to find out why the temp is going so high. Is it really getting that hot or do you have a bad sending unit?
Jun 11, 2013 | Suzuki GSX-R 750 Motorcycles
My navara d22 runs fine untill the temp reaches standard running temp then the ideal climbs to 1500rpm then why the car is driving it cuts out
I would first scan the ecu for any trouble codes , the nissans are quiet common for temp sensor fault..
Jun 01, 2010 | 2005 Nissan King Cab
Daytona 955i running hot
That is quite normal - these bikes run very hot and will typically reach temp where fan kicks in (103 deg C) while bike is sitting at idle, even if not particularly hot weather. Needs good airflow through the rad to keep the temp down.
Fortunately, when fan comes on it lowers the temp quite quickly.
Jan 07, 2009 | 2006 Triumph Daytona 955i
Raypak COMMERCIAL R407A  399K BTU ASME DIGITAL LOW NOx () Logo
41 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
