Philips viatual dolby surround tv, stays on for a minute then flicks off with EXT flashing at the top of the screen and just flicks all the time as if its trying to find the channel but doesnt
  • 3130 Answers
SOURCE: channnel keeps flicking like your changing channels with remote
when you say flickering??? are you saying the screen goes black and comes back on?? does the sound go out at the same time and comes bag on with the pic ? Is the sound there when this happens but is distorted. Is the pic blacked out or is it greying out with lines and twisting?? Need more info please as if its blacking out and the sound goes with it it may be going into shutdown. If the pic is getting kinda greyish with it twisting and the sound is there and ditorted then the tuner could be bad
Posted on Mar 25, 2006
  • 105 Answers
SOURCE: Freeview Box :(
This kind of interference can often be caused by remote pick up from energy saving lamps.
Posted on Mar 17, 2008
  • 36 Answers
SOURCE: tv will not stay on
Pull the batteries out of your remote.. If channels stop changing check for stuck button on remote..
Posted on Jun 30, 2008
SOURCE: maxim lcd tv stays on standby.
mines a advent 32lcd just went mad today ! standby light just keeps flashing fast and just won't come on at all !!
Posted on Sep 21, 2008
SOURCE: 2004 philips 60 ''projection screen hdtv model # 60pp9202/17f
Posted on Oct 16, 2008
42 Philips tv won't turn on just blue light flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Sep 10, 2015 | Philips 40PFL4706 40 LED-LCD TV - 16:9 -...
Philips Electronics 46PFL3908 46 sound distortion
sounds like you burnt up the amp chip only way to fix is to replace thw whole circuit board
Mar 24, 2014 | Philips Electronics 46PFL3908 46" 1080p...
Philips: HTS3520 doesn't use surround from HDMI feed from SKY
Check your connections and the settings in the menu.
Good luck
Mar 11, 2014 | Philips HTS3520/05 5.1 ch Home Cinema...
Cannot get surround sound to work with Philips hts3106/f7 andonic tcp50g25. It works fine for Blue ray via the hdmi out of philips dvd/receiver, but not for xbox or cable etc (only works in stereo).
i have the same system. all you have to do is when you connect your xbox 360, press the surround button on the remote and then use the arrow buttons to change it to dolby music pro2 or multi channel audio. same goes with any device you connect. hope it helps. In my case the xbox is connected to the Tv via HDMI and bluray player is connected to xbox via compoent cable
Nov 26, 2011 | Philips Audio Players & Recorders
We hooked it up and have no sound
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console for a widescreen, high-definition TV, determine your audio options, and check your console's serial number and Xbox Dashboard version.
Go to correct section for ... Audio
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
  • Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
    Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
    To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
  • Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
    The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
May 13, 2011 | Microsoft Xbox 360 Console
I'm looking to get help with the equalizer settings on my Philips 47 in LCD TV. It just doesn't sound very good....Need help
Philips 47PFL7403D have Equalizer: 5-bands
Output power (RMS): 30W
Sound Enhancement: Incredible Surround
Sound System: Dolby Digital (AC-3), BBE.
Mar 27, 2011 | Philips 47PFL7403D 47 in. LCD TV
Connect TV to dvd player
hdmi, S-video or jack are the most common cables delivered with the dvd, you can plug an amplifier between tv and dvd for a dolby system.
Turn on the DVD player, the TV and Set your TV on "AUX" or "Ext" with the remote.
Dec 23, 2008 | Philips TV Tuner Video Capture PCI Card -...
Philips 28pw6305 tv turns off
Sep 19, 2007 | Philips 28PW6305 28" TV
TV won't stay on and DVD's are stuck inside
you moust goyng to the service center becouse is one little problem the soft
Jul 24, 2007 | Philips 20DV6942 20 in. TV/DVD Combo
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
