Question about Makita UC3530A 14" Electric Chain Saw
I cut down a bush for my wife who had hammered nails into the tree. I now need a new chain. Where do I buy one quickly ?????
  • 95 Answers
Lowes,home depo , tsc ,all have chains.Or on line from ereplacementparts.com.Are a few places.
Posted on Mar 13, 2011
I bought a meridian trike from schwinn, my kids took a hammer to the chain guard and my wife is upset, is there any way I can just buy a new chain guard for this trike? Also want to put a motor plz
Schwinn Meridian chainguard - schwinnbikeforum
www.schwinnbikeforum.com > ... > WELTERWEIGHT PLUS
Oct 20, 2012 - 5 posts - ‎5 authors
A little help please... My daughter needs a new chainguard for her Schwinn Meridian. She loaned her trike out, to be used in a parade, and ...
I need a new chain guard for a Schwinn Meridian Adult - Fixya
www.fixya.com/.../t10679393-need_new_chain_guard_schwinn_meridi...
Oct 16, 2011 - SOURCE: Meridian Adult 26-Inch 3-Wheel Bike: Schwinn Meridian Tricycle rear brake adjustment... ... Schwinn Meridian Adult 26-Inch... ... Have a manual for Schwinn Meridian Adult 26-Inch 3-Wheel Bike?
Brian riding on his new Schwinn Meridian 24-inch 3-wheel ...
Dec 26, 2015 | Cycling
My poulan 18 inch chain saws blade turns but only cuts in about an inch and won't go any farther. It's two days old and worked fine cutting the first 2 trees down.
It sounds like the chain does want sharpening, it depends on what you are cutting ( type of timber, dirty timber,burnt timber etc ) as to how long before it needs sharpening, if the chain comes into contact with the ground below the tree it will lose its edge instantly.
Dec 29, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My special 42 slows down when under cutting load
Hitting the ground could just be a coincidence. Try changing the spark plug. murf427
Oct 25, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Cs310 bad oiler
This saw does not have the power that I was used to. However, I used my big Stihl to cut down the trees and switched saws to do the trim work. I had no problem starting or restarting the saw. It was easy to pull and started quickly. The chain did need to be tightened several times but that is normal with a new saw and chain. Other then being a little under powered, I found this saw to be light, easy to handle and overall a good saw."
Jul 28, 2012 | Echo Garden
I'm fixing a 83 Harley-Davidson sportster. The last owner changed the handlebars and they are loose in the tripletree. what might be the problem?
If they are loose in the upper triple tree, you need to simply replace the riser bushings in the triple tree. Look under the triple tree and you'll see either two large bolts or two large nuts. If you take these off, you should see some rubber bushings that the risers go down through. If the bushings are worn or have gotten old and spongy, simply buy some new bushings and replace them. If the handle bars are loose in the handlebar clamp, take the clamp top off and see if the handle bars are knurled or have ridges cut in them. If not, they've put the wrong bars on the bike. You may can make a thin shim and put it around the bars and tighten it up a bit. If this doesn work, replace the clamp and risers.
Good Luck
Steve
Jul 01, 2011 | 1979 Harley Davidson XLH 1000 Sportster
How to remove the drivers side door
pound out the hinge pins. Its kinda hard i think they make a tool for it otherwise a hammer and chisel. they have heads at the top like a nail. if they are worn buy new pions and bushings to reassemble
Mar 22, 2011 | 2000 Isuzu Hombre
I have a Rancher 55 18" with a new chain. Started
First thing you need to check is the cylinder.Take the spark plug ouy.use a flashlight and look down the hole towards the muffler side.If its scratched up afraid the motor is shot and will need to be rebuilt.If its not scratched up let me know on here.Then I will give you more things to check.
Mar 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Need instructions on replacing drivers side door hinge pins and bushings
  • 1. Place masking tape on the inside edges of the door, on both the inside and outside of the door. 2. Remove the door spring by using a door spring removal tool. Insert the tool into the door spring, turn the knob with a screwdriver to compress the spring, then pull out the tool. 3. Set a 5-gallon bucket under the door. This will help support the weight of the door. 4.Place a nail punch under the hinge pin, and strike it with a hammer. Repeat this until the hinge pin begins to come out of the hinge. 5.Place the end of a flat-head screwdriver under the top of the hinge pin, then strike the screwdriver with the hammer to force the hinge pin out of the hinge. 6. Place the bushing on top of the new door hinge pin, and tap it into place with the hammer. 7. Insert the new hinge pin into the hinge. Tap on the hinge pin with the hammer and nail punch to force the pin into the hinge. 8. Insert the hinge spring back into the door, and release the tension on the spring removal tool. 9. Spray the door hinge with a lubricating spray or apply grease.
    I know there are a few directions but it is fairly easy to do. If you have access to an air hammer and a compressor you can use this in place of a manual hammer to make the process a bit easier.
    Hope this helps.
  • Mar 10, 2011 | GMC Sierra 2500HD Cars & Trucks
    Chainsaw isn't cutting straight
    The odds of a bent a bar approach winning the lottery, while possible it is not likely! ALL the teeth must be of equal and opposite angles. I think a new or professionally sharpened chain will cut true.
    Pretty good quick video. There are many that are not worth watching.
    http://www.5min.com/Video/Tree-Cutting-Safety-Chainsaw-Sharpening-15094965
    By Oregon and very comprehensive. I suggest you read everything that looks remotely connected.
    http://www.oregonchain.com/pro/service/faq.htm
    If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
    Lou
    Mar 25, 2010 | Husqvarna Forest & Garden #966906636 445...
    When i try to do a horizontal cut my saw seems to bite in for a start, but then just runs free in the tree not taking a bite or drawing the saw in, this has also happened with 45% cuts, is this my own...
    Sawing with a chainsaw is mostly 2 part, a sharp chain and good technique.
    If your bar is straight, your chain is razor sharp and the oil reservoir full then it boils down to technique.
    You cannot run a chainsaw through horizontally on a big tree, what will happen is half the time the tree's weight will begin to collapse upon the bar and pinch it in the tree and you will not be able to saw any further.
    You will notice that when felling a tree the vertical cuts are always problem free because gravity pulls the off-cut away from the saw. With horizontal cuts fire your blade in at an angle, and in cut in the direction the tree (or whatever) is likly to fall. As you cut rock your blade to help it bite into the wood and resist jamming. If your chain jams do not keep on the gas for you will burn out the clutch.
    For an awkard cut instead of feeding it right through cut towards the middle to create a notch, then cut from the other side, the weight of the tree will fall on the cut portion leaving your blade free to slice through.
    Just think logically and make sure that the blade can feed through without getting pinched, this is well represented if you get a log and support both sides then cut vertically in the centre; it will get pinched imeediatly. Now cut from the underside and it will fly right through.
    This is difficult to describe but plan your cuts and test it out.
    Cheers,
    Kevin
    Feb 12, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
    Makita UC3530A 14" Electric Chain Saw Logo
    Top Makita Garden Experts
    JOHN LAPIER
    Paul Sikkema
    Paul Sikkema
    Are you a Makita Garden Expert? Answer questions, earn points and help others
