Question about GE Spacemaker JVM1640SJ Microwave Oven
My keypad is nonresponsive. I unplugged the unit once, and was able to reset it and it worked for one heating. 2 hours later the keypad is now unresponsive again. Upon unplugging/replugging it again shows reset, but the keypad is again unresponsive. Help?
  • GE Master
  • 9,047 Answers
The membrane keypad has failed.
On some models, you can replace the membrane keypad. I have uploaded a handy guide with pictures showing you what's typically involved.
On other models, the keypad is only available as part of the whole control panel frame. It's easier, but a little more expensive.
You may choose to do either yourself, or have it done for you.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Let us know here if you need further free help.
Posted on Mar 13, 2011
My GE JVM1540 microwave keypad does not work. There is power to the unit, the display reads "press start" but the keypad does not work
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still fails, you would probably have a bad door switch or mount or a bad "start" pad on your membrane keypad.
See these files first:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Once you look those over, if you still need help, please reply back with the full model number from the tag in or on your unit.
Dec 16, 2010 | Microwave Ovens
Keypad does not respond on Maytag microwave MMV5100AAQ.
What usually causes keypad failure is cleaning... spraying it directly with a cleaning solution instead of using a moist cloth on it.
Otherwise, it could be a bad door sensing switch or control PCB. If you haven't already tried this, unplug the unit from the wall outlet for atleast 1 hour and see if it might reset...
Sep 11, 2009 | Maytag MMV5100A Microwave Oven
Sanyo microwave clock reset
This is the generic instructions to set the clock. I have visited the sanyo site to aquire a owners manual with no success in locating one. This being said, here are the instructions.
  1. Unplug the unit for a minute then plug unit in.
  2. Press the clock (clock/timer) button once.
  3. Using the keypad, input the time you wish to set.
  4. Press the clock (clock/timer) button once.
  5. Press the stop/clear button, Time should remain.
Hope this works, if not, let me know.
Please take the time to give this solution a fix ya rating.
clarkco
Apr 12, 2009 | Sanyo Microwave Ovens
The display lights are all solid and nothing happens when you press on the keys. I have a GE Sensor Microwave. I bought it in September of this year. Came home from work one day, went to heat something up...
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
You may have a failed keypad.
Dec 11, 2008 | Microwave Ovens
Broken microwave
Then please let us know if the hard reset does not fix it.
(It may need work on the controller or keypad)
Sep 16, 2008 | Maytag MMV5000 Microwave Oven
My micorwave
More info on such problems:
Is it possible that some spray cleaner accidentally got into the controls?
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
Always spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
Always use the vent fan when cooking on the stove top to keep steam and grease out of the controls.
I always recommend that users spray the cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
I recommend a soft cloth since paper towels can scratch the plastic.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If it does not dry out over time, it may need to be manually dried or blown out.
The keypad may be damaged or worn out, or control unit may be damaged.
Sep 10, 2008 | Samsung MW1030WA Microwave Oven
Microwave not working
Otherwise, your controller or keypad may have moisture on it.
Sep 08, 2008 | Panasonic Microwave Ovens
Sharp Carousel Microwave Convection Oven
You may have a bad keypad.
Sep 04, 2008 | Sharp Microwave Ovens
Samsung Over range Microwave
Mine just started today too. I am thinking of taking a ball bat to it. Samsung foriegn made piece of shit.
Jan 04, 2008 | Samsung SMH7178STD Microwave Oven
Numbers and light, but no power
It sounds like you have a bad control unit (the circuit board). We repair controllers nationwide for $39.995 in most cases, but if a part is needed which we cannot get, then it will need a new board. That can be ordered from http://www.vancebaldwin.com If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 06, 2007 | Sanyo EM-P672W Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
290 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
