Question about Hobart Slicer Automatic 12"
I have Hobart 1612 slicer starts kind of slow and will slow down after a bout 40 seconds or so when using then trips my breaker. If I shut it off for for a little bit then the same thing again. Do I need a new motor or something.
ginko
  • 19396 Answers
SOURCE: HObart MOdel 1712 Slicer Sharpener
The tw sharpener stones should be fixed with the screw provided to the blade
Posted on May 08, 2008
bigg t
  • 640 Answers
SOURCE: I am trying to fix the dial on my hobart slicer any ideas
This is the deal jason,get a rubber mallet,mineral oil and a mapp torch.If you look at the guage plate this is the part that the meat/cheese goes on you will see 2 rods that connect it.Heat the rods up and put on mineral oil.Hit the guage plate down while turning the knob left then hit it up and knob to the right ,keep doing this and apply plenty of oil .It will be good as new!
Posted on Aug 07, 2008
bigg t
  • 640 Answers
SOURCE: Hobart H-600-T Mixer Shuts down while mixing bread dough
What you replaced were the contacts on the overload,correct?These 'heaters' look like springs?If so you have other issues.I'm a hobart tech and repair these mixers often.Are you mixing pizza dough?
Posted on Mar 07, 2009
SOURCE: hobart slicer 1612 need to make the product
Hi, I just received an older 1612 Hobart, and fixed the same problem.
First i disassembled the linkage from the bottom, then i used a propane torch to heat the rods and the aluminum castings (carefully, bring the temp till it is hot to the touch) Hammering doesnt work well so i made a piece of pine appx 1x1" with a notch to use as a pry stick. put a thin piece of plywood against the casting so you dont crack the housing, as it is thin alum.
Worked for me, take your time
Posted on Jan 03, 2010
  • 3 Answers
SOURCE: i have a hobart handler 135 motor stops feeding
Take the drive motor off and blow out dust, chips, wire pieces, etc. and then rinse out with contact cleaner, blow dry, re-install. Had to do this every so often with mine. Hope that helps.
Posted on Feb 17, 2010
Hobart handler 135, the wire starts to feed for about 15 seconds then slows and stops.
Hi:
Don't know how old is your unit but my guess is that your gun's liner is the problem. Have you change it lately? If not, change it. Does your machine just stops feeding the wire or does it shuts down? If it just stop then; is the liner, if it shuts down; then you have a pc board problem.
Oct 29, 2011 | Hobart Handler 140 Mig Welder
May 08, 2008 | Hobart A200 Stand Mixer
I have a 1712 hobart slicer and trying to figure out how to use the sharpener for the blade .
It fastens to the bottom of the gauge plate where the notch is. You can view or download a operator manual hobartservice.com.
Nov 16, 2010 | Hobart Slicer Automatic 12"
Anyone have the wiring Scematic for Hobart 2912 Slicer
Schematic is located on the back side of the bottom cover. Tip the slicer back and remove the bottom cover to find it. It's usually very dirty with food and, more importantly, oil. Be careful wiping oil off as the schematic often times smears when doing so.
Oct 25, 2010 | Hobart Slicer Automatic 12"
Pool pump shutting off/tripping the circuit breaker
What kind of pump are you using?
Sounds like the Intex is restricting water flow there by heating up your pump and shutting it down..
You may need to re plumb everything to handle the flow.
Intex hoses and fittings are different than the industry standards just so the can make you buy from them
Do what ever it takes to get good flow
Jul 01, 2010 | Intex Automatic Salt Water System for ...
Hobart slicer 1612 need to make the product thickness ajustment knob work . It was stuck from non use . I have tried spraying with silicon spray the two shafts, but i dont undrstand the mechanism that...
Nov 13, 2009 | Hobart Food Processors
Hello...I am looking for specs for the Hobart 300 slicer....does anyone have them? I would appreicate your help...Diana dlbwholesalers@hotmail.com The county is requesting them as soon as possible...I...
Hi Diana. Have you given us your complete model # for your slicer?
I can't find a listing on Hobart's website for a 300 slicer. Is there a digit missing in your description?
You could call your nearest Hobart parts place and ask them to email your specs. ASAP.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 24, 2009 | Hobart Food Mixers
Aug 07, 2008 | Hobart N50 Stand Mixer
Hobart Slicer Automatic 12" Logo
79 people viewed this question
Top Hobart Kitchen Appliances - Others Experts
atva20
Level 1 Expert
Colin Stickland
Colin Stickland
Dennis Boxerman
Are you a Hobart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
