Question about GE Refrigerators
Everything is freezing in the refridgerator. The water dispenser will not put out water. We have taken the temperture to 0 then back to 5 and it still will freeze in the regular compartment.
  • GE Master
  • 43,501 Answers
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Posted on Mar 13, 2011
I have a GE Profile Bottom Freezer Refridgerator. Everything I put in the fridge freezes. When I increase the temperature, it stays low.
Make sure you do not have items blocking air flow to the temperture sensor at the top left side of the refrigerator. Another thing to check would be air leakage at the air duct at the bottom back of the fresh foods section. Also, at that air duct, make sure there is an electrically activated dampener door inside (I've seen them missing), and that the damper door is not broken.
Mar 14, 2011 | GE Refrigerators
Water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
Mar 17, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Refridgerator Not Dispensing Water
did the water work before you changed the filter . water when chilled may have frozen in line. . i would before major work adjust tempt of both freezer and frig . if too cold / forzen line .. are you freezing any thing in crispers. this is a good clue.. hope this might help .. mm
Dec 07, 2009 | Kitchen Ranges
Electrolux will not make ice. the water will dispense
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 17, 2009 | Electrolux EW23CS65SS Stainless Steel Side...
FREEZER OVER FREEZING AND REFRIG NOT COOLING CORRECTLY
one of problems gas level inside system are low if its cold outside the refridgerator freezes if jou struggle email me at greyvesa@gmail.com
May 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
AMANA refridgerator water dispenser not working. Freezer door not closed properly last night.
Hello schlucks
welcome to fixya.
You said, Your AMANA refridgerator water dispenser not working. Freezer door not closed properly last night.
When the door to the freezer was left open all night,the moisture from outside caused the water line to the water dispenser to freeze!
What you need to do is to move all the articles from your freezer to a spare or second freezer
temporarily.
Then turn off the freezer compartment of the first unit where the water is not depensing .
you will need 12 to 24 hours untill the line defrosts.
If the dispenser works sooner then don't wait any longer to restart the freezer.
In some models, the fact that the freezer is turned off may affect the power in the dispenser untill the freezer is turned back on.
After you finish defrosting and turn the freezer back on. give it 24 hours to get back to running temperture.
Then reload the articles agin.
BUT DO NOT TAKE 20 TRIPS TO BRING THE PACK AGES AND LOAD IT, LEAVING THE DOOR OPEN AGAIN!
Bring the articles to the freezer and load it straight awy quickly and close the door.
This will solve your problembarring any damage to the dispenser!t
Thank You for having me advice you.
Huuum
Please remember to leave a rating!
I'm sure you are solved!
Some info!!!!!!!!!!
cold air to the bin and make it colder.
Water and Ice Dispensers
(on some models)
Depending on your model, you may have one or more of the
following options: the ability to select either crushed or cubed
ice, a special light that turns on when you use the dispenser, or a
lock option to avoid unintentional dispensing.
NOTES:
■ The dispensing system will not operate when the freezer door
is open.
■ After connecting the refrigerator to a water source, flush the
water system. Use a sturdy container to depress and hold the
water dispenser lever for 5 seconds, then release it for
5 seconds. Repeat until water begins to flow. Once water
begins to flow, continue depressing and releasing the
dispenser lever (5 seconds on, 5 seconds off) for an
additional 2 minutes. This will flush air from the filter and
water dispensing system. Additional flushing may be required
in some households. As air is cleared from the system, water
may spurt out of the dispenser.
■ Allow 24 hours for the refrigerator to cool down and chill
water.
■ Allow 24 hours to produce the first batch of ice. Discard the
first three batches of ice produced.
Oct 03, 2008 | Amana Refrigerators
Whirlpool refridgerator issue
YOU FIRST SOLUTION TO THE DRAIN HOLE FREEZING UP YOU NEED TO GET A TECHNICIAN TO HAVE A LOOK AND REPAIR IT,IT WILL BE BEST IF HE INSTALLS A PAD HEATER TO KEEP THE DRIP TRAY FROM ICING UP.YOUR SECOND PROBLEM YOU NEED TO SEE IF THE DRAIN HOLE IN THE FRIDGE SECTION IS NOT BLOCKED WITH ANYTHING IF SO HAVE IT CLEANED AND POUR SOME HOT WATER DOWN TO WASH OUT WAT IS IN THE DRAIN PIPE.GOOD LUCK.MOHAMED
Aug 20, 2008 | Whirlpool ED2FHEXN Side by Side...
Ge refridgerator model gsl25jfpe bs
I have a gsl25jfpe bs ge regrigerator and the baffle motor that controls air flow from the freezer to the refrigerator is out. This had been causing everthing in the fridge to freeze and cause the water to stop working due to water freezing in the storage tank. The baffle is in the back top of the fridge covered with a plastic cover. Remove plastic cover to check baffle function.
Jul 19, 2008 | Refrigerators
clear ice,clear drain, all the way to the drip pan, and tilt unit slightly to the rear
Apr 22, 2008 | LG LFC25760 French Door Refrigerator
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
