I don't know this machine, but I know Malber single tub machines well and this problem in the Malber machines is alost always due to a worn out heating element, similar to the heating element in an electric oven or electric stovetop range. If you have had the machine for at least several years, and noticed that the dryer was becoming less effective, then I bet it's the heating element which needs to be replaced.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Siemens WK61420GB Front Load
The agitator is not working properly. When it is in the wash cycle it is not agitating correctly. It...
(More)
The agitator is not working properly. When it is in the wash cycle it is not agitating correctly. It seems is it spinning and washing at the same time. Can it be just a belt issue?
My MLG2000AWW today after the wash cycle was done a smell of burning rubber and a little white puff...
(More)
My MLG2000AWW today after the wash cycle was done a smell of burning rubber and a little white puff of rubber smoke comming from around top front edge of washer tub in front. Need some help in troubleshooting cause.
I have a 9 year old siemans washer/dryer which has recently developed a mind of it's own. It stops...
(More)
I have a 9 year old siemans washer/dryer which has recently developed a mind of it's own. It stops during a wash cycle, if I switch it off and on again it starts and completes the wash but stops during each rinse cycle, again I have to switch it off an on every time. It doesn't do it quite so often if I use the higher water level button
