Yes, you will need a regulator at the tank that can handle the maximum Btu Output of the heater. In addition to that, you also need enough 1/2" Flexible Copper Gas piping to run from the tank valve to the heater. In the line passes through a brick, cinder block or concrete wall, the gas line MUST be sleeved with either Black Iron Pipe or Rigid PVC Pipe. You'll also need assorted flair nuts and connectors.. As well as , a Inline Gas Shut Off Valve within a minimum of 2' from the heater. You will alos need a pipe bender for flexible copper pipe.
Having a friend who has a lot of knowledge and tools for installing gas appliances (running lines, making leak-less connections, etc) really helps.
