Question about Fuji FinePix A850 Digital Camera
When my SD card is inserted it ways "card not initialized" what does that mean and can it be fixed?
  • 30 Answers
Most of the time you just need to format it, almost all cameras can format it themselves but if it won't let you just use your PC, and it never hurts to try other SD cards to make sure.
Posted on Mar 13, 2011
My Nikon Coolpix L 18 is 'stuck' on internal storage instead of SD card. Anyone know how to remedy this?
Do you have an SD/SDHC card installed, and has it been formatted by the camera?
Feb 13, 2013 | Nikon COOLPIX Cameras
What does it mean when I get a message that says "please insert memory card" on my JVC Everio GZ-MG21U?
Make sure you're using an SD card, not a higher-capacity SDHC card. The GZ-MG21U works with SD cards, not with SDHC cards.
Sep 24, 2012 | JVC Everio GZ-MG21 Camcorder
I inserted sc card backwards then removed it, now I get the message "This card cannot be used"
the card may have been bent or had scratches on its metal parts. (how bad did you force it?) if its not bent and the metal parts are not scratched see if it will show you the same results on a different machine. Since you have not identified the machine, i am not sure if the card was inserted into the camera or a computer backwards. either way the metal parts need to go into the machine. Check to see if any other items are touching the metal on the card. (and I assume you mean SD card, since this camera can only take SDHC, SD or SDXC cards.)
Nov 22, 2011 | Nikon COOLPIX P100 Digital Camera
When im inserting my micro SD memory card, it appears
It seems that the Card validating sensors are damaged. It doesn't seems to be a software problem. You will have to take the device to a repair center and get it fixed.
Nov 13, 2011 | Samsung Cell Phones
After i insert my 1 gb sandisk micro sd card into my blackberry 8530, an error message comes up: "cannot access media card due to fatal errors" i have tried to install, repair, and format it...
It sounds like in your situation that you may have a bad card. If you cannot get your card to mount to your phone for storage, I would try to find access to a pc that has an SD card slot that you can try to format it that way. If the card still wont format, your looking at a defective card and will need to purchase a new one.
You can find Micro SD cards here for purchase.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&Depa=0&Order=BESTMATCH&Description=micro%20sd&IsRelated=1&cm_sp=KeywordRelated-_-micro_sd_card-_-micro%20sd
Sep 22, 2011 | SanDisk 2GB microSD Memory Card
Good day! I have a Samsung galaxy 5 phone here and the problem that i encountered is that when I will insert an SD card to the sd card slot. it will say " Blank SD card" although that card is not...
Copy all your valid information from the SD card to your C: drive, and burn the files to CD-recordable.
Then, insert the SD card into the phone, and allow it to "format" or "initialize" the SD card for use with your Samsung device.
Jul 20, 2011 | Computers & Internet
My Lumix DMC ZS7 reads "insert sd card again" when I have a full sd card inserted. The sd card is "verbatim sdhc 4gb" any idea? Thanks in advance
SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
If your manual doesn't specifically mention SDHC cards or memory card size bigger than 2GB, then the camera almost certainly won't work with SDHC. My Lumix won't work with anything larger than 1GB SD.
Jan 18, 2011 | Panasonic LUMIX DMCZS7 DMCTZ10 Digital...
What does no card mean? Thank you.
"No card" means that either
  1. You have not inserted a memory card
  2. The memory card is not formatted, or
  3. The memory card is damaged and therefore can't be read by the camera.
How to insert the memory card:
  1. Open the camera’s battery door by sliding it downwards.
  2. Insert the SD card into the slot as shown inside the camera’s battery compartment. The SD card can only be inserted one way.
  3. Press the SD card completely into the camera and then close the door. Open the door and press on the memory card if you wish to remove it.
Note: There is only one way to insert the SD memory card into the slot. Do not force the card into the slot. This may damage both the camera and the SD memory card.
Before you can use the card, it has to be formatted:
  1. Insert the memory card into your camera as described above.
  2. Turn the camera on by pressing the power button.
  3. Use the multi-select button to select the "SET" option.
  4. Press the right arrow button to set "System" then press down key to select "Format".
  5. The default option is ‘Format’. Select this option by pressing the OK button.
  6. Select "Yes" to format the card.
If all this does not work it might be that your SD card is damaged. Try to replace it with another one. If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 08, 2009 | VuPoint DC-ST300-VP Digital Camera
Fuji FinePix A850 Digital Camera Logo
95 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
