Question about Ovens
We're having trouble setting the clock on our Kitchen Aid Superba double covenction oven. When we push "clock set/start" and enter the time, and then push the "clock set/start" again, the display goes blank. Thanks
    Problem Solver:
  • 30 Answers
Go to www.searspartsdirect.com. You can get a manual from them or you can go to www.whirlpool.com and possibly download one from there, make sure you have your model number with you.
Posted on Mar 13, 2011
Kitchen Aid Superba double oven
f5e1 is a door locking error. try shutting off power for a minimum of 2 minutes to reset the control board. If you still get the error replace the latch. Here is the part to order.
Jun 19, 2013 | KitchenAid Architect Series KEMC308KSS...
How do you get the ge profile oven time set to not on military time. we push clock time and the time, and it defaults to military time.
I don't know this particular model but on a lot of different brand stoves/ovens the clocks only work on military time. I have encountered many of these and they are manufactured to work on this time only. Unfortunately I have one sitting in my kitchen!
Mar 13, 2011 | GE Profile JTP56 Electric Double Oven
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Our kitchen Aid Superba Double Oven makes noises when we turn it on and also as it cools down. It sounds like a fan-type noise. How can we fix it?
We had the same problem. It is the fan in one or both of the ovens. we had a repairman come out because the ovens have to come out of the wall. It was a quick fix.
Oct 04, 2009 | Jenn-Air Electric Double Oven
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Kitchen Aid Superba Double Oven
Remove the oven from the wall. Remove the rear panel.
The upper and lower ovens have a non-resettable thermal fuse that has blown.
Use a VOM to verify which fuse. After repair use Easy Off, not self clean.
May 24, 2009 | Jenn-Air Electric Double Oven
KitchenAid Superba double oven: can't set clock.
If you turn the center knob (marked 'time') to the right, it sets the timer; but if you turn it sufficiently far to the left, it goes into clock set mode. When you get to the correct time, press start.
Mar 09, 2009 | KitchenAid Architect® KEBS277S Electric...
KitchenAid Superba Microwave/Oven, Microway Door message
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Dec 20, 2008 | Ovens
Kitchenaid superba 27 double oven clock - can't change the time!
I went to the website:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203177060.pdf
http://www.kitchenaid.com/custserv/service.jsp
from page 8
Turn the knob to the left until a tone is heard and "time" appears in the display window. The previously set time will appear in the display window.
Continue turning the time knob in either direction until the correct time of day appears in the display window
Press the START button to begin clock operation
Nov 17, 2008 | Ovens
Ovens Logo
181 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
