Question about Frigidaire FEQ1442ES Electric Dryer
Please could you send me a diagram of the inside of this dryer and why my dryer runs but doesn't heat
  • 46 Answers
Change element in a samung dv665j
Usually, one takes the rear cover off revealing the element area. I doubt if the heating element is burned out. Typically the small thermostat or thermal fuse link blows before the heating element goes. You would have to see the diagram of your model online. Most sites have the exploded parts view of that section online. If you don't have a meter tester you may have to replace all 3. Some models have them all tied into 1 board. This site has video troubleshooting. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-160-1067262-/Samsung-Dryer-doesn-t-heat-DV665J Samsung Dryer Doesn Heat
Sep 13, 2014 | Samsung Dryers
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire aeq7000eg0 motor doesn't run
Most of your fuses for a Frigidaire dryer are upper right hand side of the rear bulkhead. Here is a westinghouse dryer video I made In the video I look for failed components and show the various parts, explain their function, and location.
Frigidaire service manual
https://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101
Jul 23, 2012 | Frigidaire Dryers
My dryer mod rex5634kq1 stopped working
what stopped? Does it not Spin? if so it could need a new motor. If it spins but doesn't heat up. it could just be a heat sensor in the back that needs to be replaced or a heating element. if nothing happens at all it could be the start button needs to be replaced. Turn the dryer around and open up the top back panel. should be about 6 screws. inside there will be a diagram on the schematics of the dryer.
Hope this helps.
Mar 27, 2012 | Roper REX5635E Dryer
Hi, Our dryer runs but doesn't heat. We checked the power source, heating element with ohm meter but it was fine. What else should we check? Thanks.
Hi.
If the dryer runs there is no problem with power. If the appliance runs but does not heat the problem is one of the thermal devices. The dryer comprises one thermal fuse, several thermostats and the element. Thermal fuse and thermostats must be checked along with the element.
Start from the thermal fuse. The fuse can be tested reading impedance with a multimeter. If the fuse is open it will read Ohms infinity. In that case replace the fuse. Here the part: ASSY-BRACKET (THERMOSTAT) (Thermal Fuse with Bracket).
The fuse is part n.15 in Diagram one below. Click on the picture to enlarge:
If the fuse is OK, or if replacing the fuse did not help test the thermostats. You have the following parts:
THERMOSTAT - Part 11 in diagram
High Limit Thermostat -Part 13 in diagram
THERMISTOR - Part 27 in diagram
If the appliance is running the door switch should not be the problem. If you need test also the DOOR-SWITCH.
The thermostats can be tested reading impedance. If there is no heat, then one of the thermostats is open and will return Ohms infinity. Other way to test a thermostat is by jumping its contacts and running a controlled cycle to prevent overheating.
Regards.
Ginko
Aug 09, 2011 | Amana NED7200TW Electric Dryer
Dryer air is not getting hot. All other functions still work.
There are several things that can prevent a dryer from not heating.. Unplug Power Before checking.
Electric Models
1- Power- Your dryer runs on 220volts. 110 runs the entire dryer and 110 runs just the element. Your breaker may have half tripped. Check to see if you are getting the correct amount of power by using a ohm meter. Also check the power cord for burn marks on the plugin and the cord itself.
2- The thermal fuse can prevent this from heating. The thermal fuse is a sensor on the blower housing the measures the temperature of the air. There is a cycling thermistat near the thermal fuse. If the dryer temp gets over 190-220 degrees the thermal fuse will blow to cut power to the element to prevent fire. You can test this by using a continuity tester.
3- High limit and/or thermal cutoff. These are both sensors on the heating element housing. Thermal cutoff is at the top and the high limit is near the bottom above the heating element connectors. Test these with a continuity tester.
4- Heating element- Just below the high limit on the heater housing. Test for continuity.
5- Motor- The motor has to reach a certain rpm to activate a sinfrigrial switch inside the motor. If the rpm is not reached it will not allow current to go to the element.
6- Timer- Make sure you are trying this on timed dry. Sometimes people use air fluff and forget to change it back. The timer could also not be sending current to the heater.
Gas models
1- Electric ignitor- Inside the flame tunnel inside of dryer near where gas line hooks up. Usually if it glows than it is still good but check to see if it is sending and amp signal to the heat coils.
2- Heater coils are two valves that open up when the ignitor send signal saying the ignitor can ignite the gas. Heat coils will not open to send gas if it does not receive a signal from the ignotor. They look like two round disk with two wires running from ignitor.
3- Flame sensor- Change if you change the heater coils. The flame sensor could not be detecting the flame inside so it shuts down the ignitor.
4- Motor- See above
5- Timer See above
If you have any further questions or need further assistance please feel free to comment me back
Jul 28, 2011 | Kenmore 63942 Dryer
Dryer is running, but heat will not turn on
Electric Models
Gas models
4- Motor- See above
5- Timer See above
If you have any further questions or need further assistance please feel free to comment me back.
Jul 27, 2011 | Kenmore Dryers
Dryer runs but doesn't heat I have a Roper RES7646KQ2, l have replaced the following parts: 1-Thermostat 2-Thermal cut off kit which replaces (hi limit and Thermostat 3-Heating Element Still...
If I remember correctly, this model has a switch on the motor which activates both legs
of the 220 to allow the heating element to come on. There is a wiring diagram under the
lid of the dryer and should show this. Hope this helps.
Jun 21, 2011 | Dryers
On the Kenmore series 90 electric dryer, where is the thermal fuse located.
The Thermal Fuse is located on the air blower housing. Its a small white plastic component with two wire leads.
The Thermal Cut-Out (TCO) is located on the outside of the heater box on the end opposite the heating element terminals.
The reason I mention both these components is because some people confuse the two and use the words interchangeably. There is a difference between the two components and what they do.
DOUBLE CHECK YOUR SYMPTOMS:
If your dryer does not run at all, check your Thermal Fuse.
If your dryer runs, but does not heat you need to check the Thermal Cut-Out.
If you have any questions, please post back and let me know what symptoms you are having. Please include your complete model number (located on a nameplate around the door opening) so that I can determine how your dryer is configured. I hope this is helpful to you.
Jan 06, 2010 | Kenmore 73952 Gas Dryer
Dryer Not Heating
I have the same problem what do I do to fix it?
Jan 14, 2008 | GE Profile Harmony DPGT750EC Electric...
Frigidaire FEQ1442ES Electric Dryer Logo
76 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
