Then, you can just remove the photo background after shooting.
Step 1: Download and install Leawo Photo BG Remover. Then launch this software on your computer, and import the source photo by directly drag-and-drop.
Step 2: After loading picture to the program, the software will automatically delete photo background by default. For more precise adjustment, you can use Auto mode or Manual mode to smear out the area using various pre-installed tools.
Step 3: After background removal, Leawo Photo BG Remove provides a professional graphic editor. You can click the 3 icons in the right hand of the interface to edit foreground and background, as well as apply shadow to your photo. Finally, click the save icon in the top-right corner to output the project.
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't
already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
