Standbye light comes on but tv wont start - Televison & Video
Probably similar problem to that I've got. On inspection found Inverter board blown up, due to the cheap capacitors having blown. I can't get a cct diagram for this board, so can't repair it. Need a replacement.
Posted on Aug 01, 2008
Please tell me what i can do my tv wont turn on the red standbye light is on but thats all
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 10, 2014 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
I have model number televion ce32ld33band cant get it off standbye
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 11, 2014 | Televison & Video
Insignia quit working after storm
Check the fuses on the power supply board first. They usually blow when you get a power surge. You may be able to replace them and get the TV running for a few dollars. If the fuses are good then the power supply board will be the issue. The main board should not be damaged because the surge has to go through the power supply board first.
Aug 22, 2012 | Insignia NS-LCD47HD-09 47 in. LCD TV
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
My tv wont turn on, but my standbye light is on
Check the 2200uf 10 vdc capacitor in the power supply. If it's bubbled on top, replace with a 2200uf 25vdc cap.
Feb 16, 2010 | Samsung LN26A450C LCD TV
I push the on button the red light comes on, tv makes clicking sound, screen does nothing. TV has no static. I checked fuses. what should i do next?
If it is a CRT type tv. Could be the start up circuit is failing. Check it using remote to turn on the tv. If nothing happens check the fuse if ok, then you may have start up problem or, faulty high voltage section. But clicking sounds may indicate you have standbye voltage.
If you can isolate the B+ supply you can check the specified voltage if whether in spec. Then if ok then Horizontal output transistor or the flyback or other minor component like diode and the capacitor.
If you are not inclined on electronics better not mess with it. It will bite. Have a repairer check that.
Oct 07, 2009 | Toshiba Televison & Video
I have big screen tv the model is either kp-5w3500........or kp-5w8500 the ser no is 9c16172 manufac date is Sept 2002 i need help getting front panel off to get the dust out....right now it wont do...
the model number is KP51WS500 or KP57WS500. If you look at the lower edged of the front panel on each outside edge you will see two plastic plugs remove those two plugs and you will see the screws that secure the panel
Apr 23, 2009 | Televison & Video
My flatscreen emerson tv will not turn back on.
I found a way around this problem. When this happens, don't use the remote.
Walk up to the TV, then HOLD DOWN the power button and while the lights are flashing, start pushing the menu button on the TV at the SAME TIME.
Then your screen will turn on. No idea why this works. Just stumbled on it while getting ********** that this TV, I had less than a month, suddely would not come on anymore. I was about to unplug the whole thing to take back to WalMart and just started pushing button combinations and found this worked.
Mar 30, 2009 | Emerson LC320EM8 32 in. LCD TV
Funai mopdel nlc 3204bc
Sorry my tele is a panasonic viera TH-37PA60E
Nov 06, 2008 | Televison & Video
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Electro Med Services...
