Question about iBuyPower Gamer Power WA500D3 Desktop PC with AMD Athlon II X2 250 Processor, Windows 7 Home Premium (811121014902)
Not starting properly and not starting at all most of the time
  • 4 Answers
If u have the warranty valid, return the machine to the vendor. There is warranty void if you open the case, and therefore, you better return your machine for a proper investigation. The problem may be related to the failure of the PSU, power button, motherboard.
Posted on Mar 14, 2011
The timing chain gave out and it will not start
Belt or chain? It has to be timed properly in order to run. Align the timing marks properly and if it still won't start you probably have serious engine trouble.
Aug 29, 2010 | 1995 Ford Escort
Runs rough, wont start at proper timing setting
usually when the camaro runs rough that could be bad fuel injectors-o2sensor and fuel filter-thats my guess i had the same problem and i put bad gas in and the fuel filter went bad
Dec 16, 2009 | 1992 Chevrolet Camaro
Car starter not working properly
hi if the times when it dont start you just hear a faint clicking sound every time you turn the key to start the car then this indicates that the starter motor selenoid is up the shoot it will evntualy stop working all together and would leave you stranded without being able to get your car started again.
The only real solution is going to be get the starter motor replaced the this will solve your problem.
Let me know how you get on or if you need further assistance ok
Dec 13, 2009 | 2006 Dodge Ram 1500
Timing belt changed
it doesn't sound like your timing is lined up properly, it sounds like your timing is out. i recommend you check your timing to your cam and crank to ensure they are lined up
Sep 05, 2009 | 2001 Toyota Highlander
When starting it turns over but wont start ,good battery good starter has gas
Each engine, regardless of manufacturer, requires 4 basic elements, air (& air flow), fuel (& Fuel pressure), compression (at the proper time) and ignition (at the proper time).
Jul 24, 2009 | Hyundai Motor 2002 Sonata
I have changed the timing belt on a 99 Dodge Stratus with a 2.4 liter engine. All timing marks are aligned properly according to Haynes diagram and the engine will still not start. It tries to start
check your distributor position,double
check all marks again,make sure when u line up
the crank marks at #1 cyl. at compression and cam shaft marks!!
G
May 28, 2009 | 2001 Dodge Stratus
Not starting......
If the above information is correct.
1. Good Compression
2. Good Spark & Proper timing
3. Good fuel Pressure, injector pulse , injector spray, & fuel quality( no t contiminated)
4. Proper & clear air intake into engine
Then the likely cause would be a restricted exhaust. disconnect the exhaust at the manifold, and retry starting engine. keep me posted, we will make her run!
Jan 13, 2009 | 1994 Mazda MX-3
Our 2004 GMC canyon will not start from time to time.
Could be any number of thing's . Engine management system sensors . Anything mentioned on here would be a guess . Having a qualified repair shop with the proper testing equipment viewing sensor scan data is the way to a fix . Not going by peoples guess . It could be a fuel system or ignition system prblem , engine sensor etc....
047 Engine Hard to Start or No Start Scan Data for Ignition
048 Engine Hard to Start or No Start Scan Data for Starting Problems
Takes year's to learn how to properly diagnose these systems . I have over thrity year's experience , thousand's of dollars of scan tools , diagnostic equipment etc... An ever year they come of with new stuff , I go to GM tech school 4 or 5 times a year .
Oct 22, 2017 | 2005 GMC Canyon
iBuyPower Gamer Power WA500D3 Desktop PC with AMD Athlon II X2 250 Processor, Windows 7 Home Premium (811121014902) Logo
125 people viewed this question
Top iBuyPower Computers & Internet Experts
General Systems...
NOEL
NOEL
Robin Hill
Robin Hill
Are you an iBuyPower Computer and Internet Expert? Answer questions, earn points and help others
