Question about Siemens S67H GIGASET Handset With Charger - Gigaset S67H 1-Line Cordless Phone
I just got a new S67H (my second) and it doesn't register to the base (S675 IP). If I try to go under select base it has no base shown. The first handset just works fine.
  • dirk241 Mar 14, 2011
    no it didn't work.
    this answer doesn't help!
  • 2,069 Answers
Unplug base from wall power, wait for about 30 minutes to reset unit, then do the registration process again. if handset finds no base, then make sure that it is in range and have no reception problems then repeat.
Posted on Mar 15, 2011
    Genius:
  • 1,196 Answers
You can try reset your phone, Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, after which you can now try re-register it. If that did not fix the problem, let me know.
Posted on Mar 13, 2011
  • Ishola Olayemi Mar 14, 2011
    I will suggest you contact the dealer, maybe there is a settings you will need to change before you can register it.
How do you register a old uniden SSE27 handset to a new Uniden SSE37 base
The following is taken directly from the SSE37 owners' manual:
Registering a handset
If you see a "not registered" message on a handset,
you must register it to a base before using it.
1.
On the base, open the menu and select
Register Accy.
2.
On the handset, press and hold #/DND
until the handset display says
Handset Registering (about 2 seconds).
3.
Wait until the handset display says
Registration Complete (about 30 seconds),
then pick up the handset.
If you don't hear a dial tone or the display says
Registration Failed, charge the battery completely,
then try again.
Feb 19, 2015 | Uniden Lands Phones
We replaced the base unit and can not register our existing handsets because they were registered to the previous base unit. Once registered the handset's menu doesn't offer a register or...
To un-register the SB67108 handset from a base unit, SB67118 or SB67138, you will need to do these steps in order:
1. Press menu
2. Key in this sequence *883247#
3. Select deregister
4. Unplug the battery for minimum 10 seconds
5. Plug battery back in and it will want to be registered.
6. Follow the directions in your base unit manual to reregister it.
That's it in a nut shell.
Jun 08, 2011 | AT&T SB67108 Phone
I have a Eurotel E1110 device but it is asking me to register the third phone again. I do not know the pin-number so what can I do?
7.5 Registration
If you have a multi-handset system, you already have more than one handset
registered to your base unit.
You can register additional handsets to have up to five handsets per base unit,
with each handset's number (1 to ) shown on its display. (Note: each handset
1. Press and hold <PAGE> on the base station for more than five seconds, to
put the base station into registration mode. It will stay in registration mode
To register a new handset to your base:
for about 1 minute, so the following handset sequence must be completed
with in this time.
2. Press <MENU> and <UP/DOWN> to select REGISTRATION.
3. Press <OK> and you are requested to enter the 4-digit system PIN.
4. Enter the 4-digit system PIN.
5. Press <OK> to confirm, and the display will show SEARCHING.
If the handset registration is successful, you will hear a confirmation tone and
the <antenna icon> will stop flashing.
The handset will automatically be allocated the next available handset number.
This handset number is shown in the handset display in standby mode. If the
handset registration is unsuccessful, the <antenna icon> will still flash.
I Used 0000 As the default pin when asked.
Hope this helps you
Jun 11, 2010 | Lands Phones
Handsets do not register
Press the END button to exit or erase the message. Press Menu/Select. Scroll uo or down to find Register Base. Select the option, select it and put the handset in the charging cradle of the base. A confirmation beep will sound.
Jan 11, 2010 | Uniden DECT 6.0 Cordless Telephone...
I can not register
go to menu and under phone settings, select REGISTRATION. and when it tries to look for the base, press and hold the page button, and voila, the phone is registered to the base.
Apr 24, 2009 | GE 28300EE1
Can't register new handsets
with in this time.
Hope this helps you
Apr 10, 2009 | Lands Phones
How do i reset philips voip4332b ip phone base unit to company default.
This should solve your problem:
1. On your phone select: Menu > System > Base Select
Select "Auto" and press "ok"
2. On your phone select: Menu > System > Register
(you might be prompted to enter a PIN if so the default is "0000" )
3. On the base station press and hold down the  "Page" button for 4-5 secs until the green light starts to blink. At this point the phone should be now able to find the base station.
Aug 19, 2008 | Philips VOIP4332B/37 IP Wireless Phone
Unregistered, registering a new base, faillure....
IF YOUR HANDSET WAS WORKING AND THEN STOPPED WITH "UNREGISTERED":
If lowercase unregistered is in main display and a reg. appears under the left soft key:
Press the left soft key below REG. and then press and HOLD the button on the top of the base station until the two indicator lights on top of the base station turn off. Wait until handset signals with beeps and registered. You are done
THIS IS FOR FRESH OUT OF THE BOX REGISTRATION OF UNREGISTERED HANDSET
Press REG Register shall be highlighted.
Scroll to Register. Press Select.
Enter the system PIN (Default: 0000). Use
CLEAR to correct typing errors.
Press ENTER to confirm.
• Your handset starts searching for the base.
Press and HOLD the round button on top of the base unit until the two
indications turn off.
• If registration is successful, the signal icon
Jun 22, 2008 | Philips VOIP8411B/37 IP Phone
TWX977 submersible unable to base register
push menu on base station - select register phone
push # sign on twx977 phone at the same time
phone will register on 9485 base station and unit
Sep 09, 2007 | Uniden TRU9485 Cordless Phone
Siemens S67H GIGASET Handset With Charger - Gigaset S67H 1-Line Cordless Phone Logo
232 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
