Question about General Electric DHDSR46EGWW Dryer
GE Dryer DHDSR46EE1WW TOOK DRYER APART TO CHANGE BELT. DONE DISCONNECTED THE WIRING BEHIND THE TOP PANEL, HAVING PROBLEMS FOLLOWING THE DIAGRAM PROVIDED BY THE MANUFACTURER. IS THERE A DIAGRAM FOR DUMMIES TO RECONNECT THE COLORED WIRES?
  • 4,323 Answers
Hi
Please check the below wiring schematic---
Hope this helps... Please post back if you need more information.
Daniel
Posted on Mar 13, 2011
Control panel turns on but dryer won't start. Start/pause button just beeps when pushed. Opened the front panel to the door switch with multimeter. It looks fine.What could be the issue?
your gonna have to go deeper than the door switch,do you know you can't get the blower motor for this dryer anymore,i don't know why they had to have two motors in their dryers?could be a broken belt,computer issues,bad t-stat or thermal fuse,the only way to tell is by checking it out with meter,also make sure you have 240 volts coming to the dryer,go in the back where the cord connects to dryer and check it there,there's no one answer for this problem,you just have to take it apart and start reading out the thermal fuse high limit t-stat,stuff like that,to find out.i remember the first time i worked on this style dryer,it took me around 20 minutes to figure out how to get it apart,some jerk put the control panel screw behind the knob,had to pull the knob off and then remove the screw to get the top off to take it apart lol,and they have a funky belt setup and two motors,i gotta tell you i would never buy a ge dryer,to much just to dry clothes.sorry i can't help you out with an answer,you can go here,put your model number in and see the parts in your dryer
https://www.searspartsdirect.com/model-number/dpvh880ej0mg/0432/0151200.html
like i said,i only worked on one of these style dryers and it is different from regular dryers,if you can't get it open check the control knob,pop it off and as far as i can remember,this was like 8 years ago i removed the screw behind it,then you can get at the screws to remove the top panel to get into it.wish i knew that at the time,thought it was just gonna be a regular ge dryer repair
Feb 19, 2018 | GE Dryers
DHDSr46ee1ww has new heating element and switch but will not start.
Have you checked the motor kill switch? Its located by the motor.When the belt comes off the idler pulley actuates this killing power to the machine. Sometimes the switch goes bad over time and needs to be changed. The part number is wd21x10261 and runs around $12
May 18, 2012 | Dryers
Remove front panel ge spacemaker dryer
Here's the trick: The Spacemaker dryer is the same as many other GE dryers but is upside down!
1. Unplug the dryer.
2. Flip the dryer upside down so the white panel is now on top and the unfinished steel panel is on the bottom.
3. Remove the 2 screws that connect the bottom, white panel from the back and lift up to remove.
4. Pull off the Settings and Fabric knobs on the front of the dryer. Take off the front control panel (remove the 2 screws).
5. Remove the 2 screws that attach the front panel (located behind the control panel you just removed). Hold the dryer drum by the top edge and pull the front panel away (note that the panel will be hooked to the rest of the dryer at the bottom corners). DO NOT PULL AWAY ENTIRELY!
6. Disconnect the wiring that is attached to the front panel (these come apart easily by hand but you might want to mark the wiring so you know where to connect it when reassembling).
Apr 05, 2012 | GE Spacemaker DSKS433EB Electric Dryer
Need diagram of belt installation for dryer DV218AEW
Hi mcpitts...
Click on the link to find your model number link http://www.repairclinic.com/Appliance-Parts
Here is the process for taking your dryer apart mentioned above.
You will need to decide which video fits your machine appearance.
This video will show you how to take apart your dryer and change your belt if the lint trap is on top of your dryerhttp://www.youtube.com/watch?v=CFnXwmUb4f4
This video will show you how to take apart your dryer and change your belt if the lint trap is inside of your door. http://www.youtube.com/watch?v=rtATa0a28bE
This video will show you how to take your dryer apart and change your belt with the control panel in the front side panel rhttp://www.youtube.com/watch?v=zpUqCrLaI7g
If you happen to run into an issue with your belt and pulley configuration all the diagrams are here click on the linkhttp://www.repairclinic.com/Dryer-Belt-Diagrams
Please take time to rate me
Aug 10, 2011 | Samsung DV218AEW Electric Dryer
I have a Maytag Dryer model # MDE5806AYW Quiet Series 200 today we had to replace the belt but we took the top panel off the dryer including the control panel and disconnected the wires but now i forgot...
http://www.apwagner.com/large_image_viewer.php?image=images/diagrams/00191/i385263.GIF
Here is the link to the wiring diagram for your dryer, I'm assuming you are looking for the wires as they connect to the incoming power cord? They appear to be the only ones with that specific wire color code.
Hope this helps!
Jul 13, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a GE profile harmony gas dryer that says "a problem has been detected call 1-800-GE-Cares' on the display. I just finished putting in the new dryer drum that fell apart. Any suggestions? Reset...
If there were no problems before replacing drum I would go back and make sure all 3 wiring connections are made behind the door panel. From there this machine is too complex to diagnose over the phone.
Mar 03, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
General Electric DHDSR46EGWW Dryer Logo
467 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Tyler T
Level 1 Expert
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
