Question about Hitachi Televison & Video
The tv looks like it is out of focus and really red can you help me get it to a clear pic
  • will200282 Aug 01, 2008
    thanks for that i'll have a look and get back to you
    Master:
  • 382 Answers
There is some kind of red convergence!..Please try to check for the circuit and find the defective bulbs or fuses and replace them which could have possibly occured due to a power surge or short circuit..
Please post back how things turned or for further assistance..Thank you!!..
Kind Regards!!...
Posted on Aug 01, 2008
I took some pics with celebrity they are blurred can i email them to you to get cleared up very dissapointed
Blurry pictures are not an easy photoshop fix. If the image is out of focus or has a motion blur it will be very tough. It really depends on what you are looking to use the image for as well. Sharpening can help but will be noticable if you try to make a large print.
May 08, 2014 | Vivitar Cameras
Does it take some type of gel under the lights, the colors are a little blurry
i also have this tv. i removed backcleaned mirrior, back of screen and lenses VERY GOOD. Then turned on tv go to convergence, sepaerate cross hairs then adjust focus on lenses. Then lenses rotate maybe about a 1/3 turn total by hand. Grab ring that houses lenses and turn until cross hairs are as clear as possible. This can be done with out help by watching inside of screen. red and green are adjustable, the blue is adjustablealso but i couldnt find blue cross hairs, maybe by covering red and green lenses the blue will show on screen. anyway when done and cross hairs are clear,lenses, mirror and screen are clean, you can adjust covergence and get a very clear screencleaning will also brighten pic. Pete
Mar 27, 2010 | Philips Magnavox 9P6034C 60" Rear...
My tv needs readjusted (color,focus,etc.)Is there an easy way to do so myself? i got a 1986 45'' RCA projection tv.it started of with just a blury spot across the top but after i messed with it the whole...
First pull back Look for screen and focus block you will have 3 controls ontop for focus and 3 controls below for adjusting screen drive to each Tube R/G/B
turn color off on Menu NOW try to Adjust the red,greenand blue screen drives as close asyou can to a Black and White picture then turn Color back on in Menu also adjust Focus for each Tube Be sure to Clean Top of Tube Lenses of dust&dirt Just in case Post me your Model and Chassis Number it will be on back of TV some RCA Focus&screen drive Block maybe in front of TV if so remove front bottom panel their you will see control box.
Nov 10, 2009 | Televison & Video
The blue projection light is off, like it has dust on it. so unscrewed the front screen, cleaned the lights now the red and green are blurry looking. any help ?
You probably knocked or moved the focus lenses when you cleaned the lights (these are actually 3 picture tubes) Each lens has a wing nut that tightens to lock the focus in place if this was moved your focus would be off. Does the blue tube light at all? and when the TV's on is the image clear when you look directly into the Tubes? (the image should be bright and clear -not milky.)
Oct 16, 2009 | RCA P52960 52" Rear Projection Television
How to fix fuzzy pic & red,blue,green lines on your screen?
Typically this is due to a convergence chip failure. This repair can be done pretty easy with the proper instruction. Have a look at this video to help determine if you truly have a convergence problem.
Jan 26, 2009 | Toshiba 57H82 57" Rear Projection...
Archos 705
Make certain the cables are going into "in" sockets, The Red (right audio) White (left audio) Yellow - video. If the TV has a scart socket on you can get a scart to phono leads with the same combination sockets red, white, yellow.
Oct 03, 2017 | Audio Players & Recorders
Toshiba 43vj13p
if the people in the pic has red out lines or looks like theres two of them then sounds like convergence problems which you will need to replace the convergence chips which cost around £150 +vat. hope this helps
Feb 10, 2008 | Philips 50P8341 50" Rear Projection...
Blurred pic on tv
you can take the back off find your flyback (the big part with a red or pink wire going to the picture tube) and adjust the small pot or potentiometer closest to the top while the set is on in front of a mirror and try adusting the focus control.
if cant get nothing but blur replace the fly or focus assembly if not built in the fly. I would change both.
Jan 26, 2008 | Hitachi C21RF39 21" TV
Blue (actual) lamp out of focus. Picture is washed out and milky.
I found a local tv repair guy who sold me the the CRT fluid for $80 and I gave it a go. It wasn't easy, but it worked. If you are really interested I'll tell you how I did it.
Aug 11, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
