Question about Siemens WM14S794GB Front Load Washer
The machine gives a 'Update Error Operating Unit' The Error started after a power shut off. we dont jknow how to fix it
Please check the following link
http://www.productreview.com.au/p/bosch-was32742au.html
I had the same problem!
Posted on Aug 18, 2011
Does not tun after windows update
I am looking for a free manual for the Nina 787BD Overlocker machine by Bernina.
Dec 21, 2013 | Computers & Internet
My windows Vista program stops operating every day at 3:00PM. How can I stop this from happening?
go to the control panel,go to power set up,there you can ajust how the the computer shuts down after a set time ,put =never and then only shuts off by the main switch
Jul 09, 2010 | Dell Dimension E520 PC Desktop
My unit shut off now displays E1.
Sharp updated the procedure for resetting the E1 code.
1. unplug unit
2. hold the Power button while plugging the unit back in
3. keep holding the Power button until the unit beeps
4. unplug unit again
5. plug it back in and it should be good
Here is the updated user manual
http://www.sharpusa.com/downloads/archives/product_manuals/air_man_AFS100FX_S120FX_S125FX_R100FX_R120FX.pdf
Jun 05, 2010 | Sharp AF-S120FX Air Conditioner
My Kenmore Elite He washer is only 4 years old, it's motherboard has already been replaced about 2 years ago and now it powers on you set a cycle and the lid does not lock. Push stop (like to add clothes)...
faulty lid switch I have had to work on a couple of these inside the machine there should be a technicans sheet so that you can do a diagostic test of the machine which will give you an error code dont be surprised with this unit if when you fix one thing that it gives you another code. I think the last one i worked on i had to replace motor harness lid switch and main control board before it stopped giving me error codes hope this helps
May 01, 2010 | Kenmore 24032\24036 Top Load Washer
I have a HP pavilion a6119h desktop. After downloaded updated and shut down two days ago now it doesn't want to boot up or power up.
Try to start the pc in safe mode (pressing F8 at start up will give you this option) then choose system restore and reset to a date before the update this should fix your problem. PS i dont think id try that update again
Oct 30, 2009 | HP Hewlett-Packard GG041AAABA Pavilion...
E000000-0001
Okay, to be of real help you have to reset the error in service mode as the officetech1 said. To do this you need to press the head key (the head with the star inside) then 2+8 together and then the head key again. This will get you into service mode. Then select 'COPIER' then 'FUNCTION' then 'CLEAR' then select 'ERROR' or 'ERR' press 'OK' then switch the machine off and on again. This may get it working for a while or a long time. But if not, you will need a fixing film unit to remedy the problem.
Mar 10, 2009 | Canon imageRUNNER 4570 Copier
My Sharp copier gives a CH error when turned on.
One of your doors is not shut all the away or dv unit is not installed.
Feb 12, 2009 | Sharp AL 1631 Copier
System shuts down after surfing the internet
Regarding the error code, all you need to do is update your driver. You can do this by downloading the most up to date driver from motorola here.
Unfortunately, it seems like this might be two seperate issues.
Sometimes machines, especially laptops but it will happen to desktops as well, will shutdown when they are overheated in an attempt to prevent damage to the physical hardware. Judging by the "after about 15 minutes" comment, I think this might have something to do with it as that 15 minute window would give a non-functioning fan or unventilated laptop enough time to overheat your machine.
If the driver update does not stop the random rebooting and you do not think the machine is hot when it reboots, do this:
right-click My Computer and choose Properties; click the Advanced tab. In Vista, click the Start button, type System, Properties, Advanced, and press Enter. Click Continue if prompted by User Account Control.
In all versions, click the Settings button under 'Startup and Recovery'. Uncheck the Automatically restart box, and click OK twice. The next time the problem occurs, instead of rebooting you will likely see a text screen reporting a system error. Report back with what error it gives you.
Nov 30, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Emachine
Probably the only solution is to reinstall all the programs (starting with the Operating System).
If your unit came with a Disk, insert this before turning on and then follow the instructions after you have turned it back on.
Good luck.
Apr 13, 2008 | E-Machines eMachines Desktop PC
After a while dont want to power up
Hi there, i spend time with customer support and we fix the problem, you have to download the last bios update and give an update to youre machine. It does not matter if you have the same version all ready install, re installed again. This should fix the problem, it did for me.
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
Siemens WM14S794GB Front Load Washer Logo
1,458 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
