Question about Directed 434MHZ Remote Control
Tv codes for samsung vcr remote model numbernr-5238
Need the tv code for akai tv for this remote and how do i prgram it in
Try these two codes. 002 or 008
Posted on Aug 16, 2008
How to I program my remote to control VCR
First find out the setup codes for your device.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Oct 10, 2012 | Philips Universal Remote Model SRP4004
Need to program remote for akai
Hello
You want to programme your Akai TV with a universal remote control; I assumes, and posts this solution.
Three digit universal remote codes for Akai TV are:
002/ 0030
Direct Code Entry
Feb 03, 2012 | Televison & Video
I have a all for one remete urc#4063b06 need code for samusung tv/vcr modelcxa192680b
There is no code for Samsung TV/VCR combo units. Try the Samsung VCR codes: 240, 045 and the Samsung TV code: 060, 427, 056, 030, 019, 178 . Program the VCR and the TV buttons separately.
Most One for All universal remote manuals and code lists are available from: http://www.oneforall.com/support/manual . You may need to change the country listed at the top of the page. Then use the drop down menus to select Universal Remote and the model. The direct link to the manual for the URC4063 is http://www.oneforall.com/uploads/support/00b313f46269f3fc78988edae4518f03.pdf .
Please note that the codes programmed into a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your TV/VCR is newer than your remote, you may need a new remote.
I hope this helps.
Oct 03, 2011 | One For All URC-3021 Remote Control
We have a sanyo tv and a ge tv remote control and we need the code 2 program the remote 4 that sanyo tv.. helppp
hi,
you didn't specify the brand and model number of your remote . any way follow the steps to prgram your remote with your tv. if it is GE universal remote. any other brand contact me back with its brand and model number.
1.Manually turn on the device (TV, VCR, DVD, etc.) you wish to
program.
2. Press and hold the CODE SEARCH/SETUP button on the remote
until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming
(TV, VCR, DVD, etc.). For AUX, press AUX then the device button
you are assigning to AUX. The INDICATOR LIGHT will blink then
remain lit.
4. Enter the three or four digit ( or three digit)code for your device using the number
buttons in the GE Universal Remote. After your code is entered the
INDICATOR LIGHT will turn off.
5.Aim the remote at the device (TV, VCR, DVD, etc.) and press the
POWER button. Your device should turn off.
code for your tv if the remote is 4 digit one
0049, 0097 ,0110 ,0004
code for your tv if the remote is 3digit one
004, 012, 013, 049, 097, 108, 110, 180, 209, 268
ok
Feb 02, 2011 | Sanyo DS31590 31" TV
Got a ge tv universal remote control...trying to get it to work on sanyo tv..had it work b4 but the person who helped do it isnt here...please help us
hi,
you did't spesify the model number of ypur remote . any way follow the steps to prgram your remote with your tv.
program.
remain lit.
code for your tv if the remote is 4 digit onep { margin-bottom: 0.21cm; }
code for your tv if the remote is 3digit onep { margin-bottom: 0.21cm; }
ok
Feb 02, 2011 | GE Televison & Video
Remote that came with tv wont work
I stumbled across this page while the owner's manual for my remote was lost. I've now found the manual (after not having any luck finding the solution on the web)!
The AKAI KC02-D2 remote operates my AKAI PDP42Z5TA 42" Plasma HD Television. It may work with others as well, but that's the TV I use it for. If the batteries are removed (or dead) for a while, it will lose its programming. Here's how to reprogram it.
AKAI = 231, 218, 221, 222, 225, 226, 227, 228
1. Turn on the Device you want to program. The remote can be programmed by pressing the 3 Digit Brand Code number listed in the code table of this programming guide. If multiple codes are listed, you may have to enter several codes to complete the steps below. (Note: For programming the VCR, a tape must be loaded/inserted first.) If your Brand is not listed, please use the Manual Search menthod or Auto Search method (Section C & D below).
2. Press and hold the SET button for about 3 seconds until the current Device LED lights (TV, VCR, DVD, STB.), then release the SET button.
3. Press the device button you want to program (TV, VCR, DVD, STB.) then the selected Device LED will light on.
4. Enter the 3 Digit Brand Code for the desired Device. For example, enter "2" "1" "8" for AKAI TV. When entering each digit, the Device LED will flash one time. After all 3 digit numbers are entered, the Device LED will turn off. If the code is not valid, the Device LED will flash three times then turn off. Check the code list and repeat from the above step 2.
(*The manual contains a huge list of 3-digit codes for various devices. If you're looking for a specific one, just ask.)
Nov 22, 2008 | Akai LCT3215/26 32 in. LCD Television
Lost remote for akai tv/vcr/dvd set
I think you should look over the Internet to buy one from places like Ebay for your brand of TV.
Apr 07, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Remote code to operate Akai TV
Non-compatible coding. Sorry...accordianman
Mar 21, 2008 | LG V181 DVD Player/VCR
Borken remote; universal remote doesn't work!
I have had on order since December 2007 the Akai replacement remote #WIR3500001-EQ01 the Akai TV/DVD combo model #CFTD2011. I called each month for 5 months, being told each time that it was on backorder. A few days ago, I received a letter in the mail stating that this remote is no longer made and is not available.
I too have tried universal remotes without any luck. If anyone has a resolution, it would be greatly appreciated.
Nov 19, 2007 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Televison & Video Logo
256 people viewed this question
Top Directed Televison & Video Experts
ted dux
Christopher Stearns
Are you a Directed Televison and Video Expert? Answer questions, earn points and help others
