Question about Toro Garden
I have a Toro Model # 38035 and I am trying to find out what year it was manufactured. Thank you. George
Need a model 51609 mnual
Please check the serial number or year of manufacture for your Toro Ultra blower. Toro has the manual for these units on the product site: https://www.toro.com/en/homeowner/yard-tools/ultra-blower-vac-51609 . Scroll down and expand the Parts & Manual section. Select the correct link for your model. Then expand the Manuals section. For example the manual for the 2015 version of the 51609 Ultra Blower in English is here: https://www.toro.com/getpub/61505 .
I hope this helps.
Oct 08, 2016 | Toro Garden
How do i breakdown hydraulic pump for a toro z255
I need a model and serial from the pump itself, toro does not manufacture hydraulic pumps, so it should be a Parker or a Hydro-Gear more than likely. Post a follow-up with the model and serial from the pump and I will try to help if I see the post ever again.
Oct 01, 2014 | Toro Garden
Where can I fiind a manual for my George Foreman portable propane grill model # GP160A and also the recipe booklet? Thank you.
Google the make and model with the worda manual at the end. You will find many sites offering you manuals to download. As for the recipe book, you could get it from the manufacturer's website.
May 08, 2011 | Vacuums
I have a Toro Z14-38 TimeCutter Model No. 74402 ride on lawn mower. Could you possibly supply me with a copy of a mechanics worshop manual for this mower? I already have an Operators Manual. Thank...
We don't have access to the manufacturer's manuals here at FixYa.com, but you can purchase one directly from Toro by following this link:
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=30166&control=SetCommunity&CommunityID=225&PageID=30031#manualsResultPage
Bill B.
Dec 05, 2010 | Garden
Toro snowblower///// tecumseh# on motor is H35-45598R SER 5283B
Usually that is a sign of the carb not being adjusted right. Run it at full throttle and adjust the main mixture needle (usually on the bottom) until it runs the smoothest. Set it in the middle of the range where it runs smooth. Then set it down to idle and adjust the idle mixture until it runs smooth at idle. Accelerate it rapidly and if it bogs or hesitates turn the idle mixture a little leaner (clockwise) and try again until it works right. That should get you very close. Try tweaking it a bit from there. as the microscopic specks clean out of it, it may need more adjusting.
Nov 25, 2009 | Garden
I have 6.5 hp toro mower and the self propelled wheels quit working. I need to know how to fix it - THANKS
Not sure which model you have, but the rear wheel drive that I have, 20070, transmission goes out every year. Toro had a real bad design on that transmission and they know it. They made a change in 2009 models to try and eliminate the problem and also give a lifetime warranty on the transmission. Model years 2006 thru 2008 has a single bearing on a half shaft and the torque of the drive belt is too much for that single bearing. I am on my second replacement and had an extreme conversation with Customer Service. Go past the first level, "Sorry It's Out of Warranty" to supervision and let them know about their product and insist they repair it. This has been going on for a month for me but I think you have to push these manufacturers to do what is right.
Oct 04, 2009 | Toro Lawn Mower With Toro Power Tools
Toro model 20038 self propel problem
Try taking the back wheels off and lubricating the joint cogs and wheels with ,say, 3 in 1 oil . The dealer recommended doing this once every couple of years as preventative maintenance when I bought mine , and it has solved sticking problems for me .
Sep 12, 2009 | Toro Lawn Mower With Toro Power Tools
I have to prime the toro mower every time I empty the bag to get it to start?
  1. what is the model, manufacturer and year of mower?
  2. has any maintenance been performed on this mower?
  3. if no, try replacing the spark plug and air filter (it's possible the spark plug could be fouled and/or the air filter is clogged) be sure to follow the manufacturers recommendations for oil, gas, filters and plugs.
routine maintenance involves:
  1. sharpen/replace blade
  2. oil change
  3. replace air filter
  4. replace spark plug
  5. new gas
Aug 31, 2009 | Toro Lawn Mower With Toro Power Tools
Trouble starting my old Toro mower
This is a 20 year old mower. Has it been used on a regular basis over recent years? Try spraying some carburetor cleaner down the carb throat to see if it fires up. If it's been sitting for awhile, the carb may need to be cleaned out.
Aug 16, 2009 | Garden
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
