SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
SOURCE: door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
SOURCE: can a chest freezer be used in an unheated garage
why not then when its down to zero shut the unit off and open the lid and free freezing...no electricity required....remember pop machines sit out in all types of weather
SOURCE: I have an Electrolux Intuition Chest Freezer. The
you need to clean the condensor coils with a brush or compressed air
