Question about Toshiba Computers & Internet
Cannot boot up When plug in battery indicated charging but when press power button, it on for 1 second the off then after 5 second it repeated the same thing.... Can't get it to turn on HELP...
  • Orlando Torres
    Orlando Torres Mar 13, 2011
    What is the model?
  • Art Ellison
    Art Ellison Mar 13, 2011
    Are you trying to use the computer with just the battery?
    Are you trying to use it with the battery and the power plugged in?
    Have you tried to use it without the battery?
    Master:
  • 525 Answers
Try taking out the battery then connecting the ac adapter. Then try turning it on.
Posted on Mar 13, 2011
Why wont my hp 4530s boot?
This indicates one of the following:
1. Dead Battery
2. Incompatible Charger
3. Incompatible battery
4. Static Charge Overload - Take out battery, unplug charger, hold power button for 30 seconds, put battery back in, plug in charger and press power.
LB
Jul 13, 2014 | HEWLETT-PACKARD Probook 4530S 156 I52410M
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
My nokia e71 loops and does not come on
Hello"::"
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 22, 2013 | Nokia E71 Smartphone
Computer will power up but not boot. Screen remains black. Battery charges.
If the screen's backlight doesn't come on at all, that's a new screen. You can find more from Gateway's support website. If the screen lights up but stays completely black, that's a motherboard issue, same fix. If the Gateway logo comes up but never goes into windows, that's most likely a hard drive issue, same fix. If you see an error message from Windows, that's a Windows issue. You could use the recovery DVDs that came with the system to fix that. Just put them in and turn the computer on. Press F8 repeatedly until you see an option to boot to DVD. Then follow the instructions.
Please rank if this was helpful.
Mar 05, 2011 | Gateway MX8711 Notebook
Acer aspire 6920 battery problem.. laptop only recognizes the battery and will not charge now... and only lasts a few minutes
1.Remove ,the battery and adopter from your machine.
2.And then press the power button form 36 Second.
3.And then refix your battery and adopter to your machine.
4.boot your system
1.first Instal the E-power management to your machine.(Didn't had means kindly download the application from our website www.acer.co.in.
2.fully charge your battery till 100% without any interption
3.now you work with your laptop untll it would be the 0%.
4.Kindly repeat the steps four times.
5.After that you Defently feel,your battery backup will increase.
Nov 16, 2010 | Acer Aspire 6920 Notebook PC
I DROPPED MY REMOTE AND THE BATTERYS CAME OUT AND NOW I CANT TURN THE CHANNEL SO I NEED TO KNOW HOW TO PROGRAM MY REMOTE
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Thanx
Jul 29, 2010 | Hitachi CLU-5713TSI Remote Control
My toshiba satellite L300 has no power
Please follow these steps VERY CAREFULLY:
1) Unplug the notebook from the ac adapter (charger power cord)
2) Take off the battery pack on the notebook
3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
4) After 15 seconds, let go of the power button
5) Now plug in the AC ADAPTER (OR CHARGER POWER CORD) ONLY (DO NOT PUT BACK THE BATTERY PACK)
6) Now press the power button once.
7) If the unit boots, the unit suffered a slight surge
8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
I hope this helps and let me know how it goes afterwards
May 03, 2010 | Toshiba Satellite Pro L300 Notebook
D600 laptop boot problem
The D600 is plagued with power up problems for 2 reasons. First the connector on the motherboard to the power button is very sloppy and after awile it breaks contact. If you put pressure under the docking port area and press the power button it may start. The second is the memory slots. I know you said you replaced the memory, but it is the slot that is a problem. Remove the memory and put 1 chip in "A", then press down on the chip while trying to boot the laptop. If this works then get a peice of foam or pad and place it on the chip. When you put the cover back on it will push down on the chip and should boot. Repeat this process for "B".
The green light does signify a charged battery! This is also a possible reason for not booting. Remove the battery and try to boot with only the power supply. A shorted battery will stop the laptop from starting up.
If all of this does not help then remove the battery and the CD Rom, then try to boot. Finaly if nothing helps you should buy a new Laptop or a used one on E Bay. You could get a used D600 on E Bay that has a good motherboard for cheap money and use your drives and LCD. I work on D600 and D800 all the time. Let me know how you make out!
Dec 09, 2009 | Dell Computers & Internet
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
