Question about Sewing Machines
E123@aol.comMy needle on my Bernina 1530 Inspiration just stopped going up and down whether I use the foot pedal or manually attempt to move the needle
This happened to me last year. When I took it in to be fixed, they told me it had to do with the long/basting stitch. They way it works it that the needle doesn't move for one stitch while the feed dogs move forward. They mentioned that I should use the long/basting stitch every so often so that it doesn't stick.
Now I'm having a problem with the bobbin thread not being pulled thru when stitching. I think something is out of alignment in the bobbin casing. Anyone have an idea how to fix it?
Posted on Mar 28, 2011
  • 86 Answers
This sounds like you have the machine in bobbin winding mode, just refer to your manual to take it out of bobbin winding mode. I'm not familier with your exact model, but the is typically a lever, or button that is used to wind bobbins, so the needle doesn't keep sewing without the bobbin thread in place.
Please rate my solution thanks
Posted on Mar 13, 2011
I have a Bernina Patchwork 140. How do I change the needle to stop in the down position? The sewing manual is no help.
As far as I know, the Patchwork 140 doesn't have a needle stop up/down button. You'll need to use the hand wheel to bring the needle up or down, as needed. The Bernina machines that have a needle stop up/down button have this button below the LCD screen. (On those machines, it's usually the left-most button below the LCD.) I suspect the index giving a page number for the Needle Stop Up/Down button is a artifact of using the same index for multiple machines.
The manual for the Patchwork 140 is available at Manuals Lib here: https://www.manualslib.com/manual/1002243/Bernina-Activa-131.html . The Bernina 135 has the needle stop up/down button. See https://www.bernina.com/en-US/Support-US/Machines/BERNINA-activa/BERNINA-activa-135 . The manual for this model is https://www.bernina.com/getdoc/90f75840-2b12-4f46-88f2-76f09e35d8d4/030529-52-04_0303_a135-a145_EN .
I hope this helps.
Jul 31, 2017 | Bernina Sewing Machines
What is smart pedal foot control for Bernina? I have a Patchwork Edition 140 and needle stop down should be controlled by pedal according to shop. I don't understand.
The foot control you are talking about will activate the needle down function on your machine. You need to press down on your heel on the foot control. This was the precursor to the automatic needle up/down option that is found on newer sewing machines that will automatically stop with the needle in the down position.
Mar 12, 2017 | Sewing Machines
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
Bernina 1030 starts by itself and runs very slowly some time after parking the needle at the top
This is most likely a fault in the foot control. Normally supplied with this machine is a Type 10 and this can be fixed quite easily but probably not by the machine's owner unless you have some electrical and mechanical experience.
If you have knowledge of and access to a multimeter, you can test it. What working properly, you will find the following:
Pedal released: resistance is infinite (anything around 4k Ohms or less and the machine will run).
Heel pressed: resistance is about 10k Ohms.
Toe steadily pressed from nothing to all the way down: resistance is infinite then after a small depression, jumps to about 4k Ohms steadily decreasing to zero as the pedal reaches all the way down.
Your problem, being at the point where the pedal isn't pressed suggests that there's some contamination in the pedal. It's also possible that you have a type 365 pedal (as used on the 930) and this is more likely to give this kind of trouble due to the use of carbon brushes in this foot pedal.
Feb 07, 2014 | Bernina Sewing Machines
Needle won't stay in left position when using zip foot - bernina 1530
Is it possible you're using a later foot with the sensor lenses on it ... your machine has the optical sensor for the automatic buttonhole foot and I'm wondering if you're getting it confused by using a foot that is not designed to go with that machine ?
Nov 04, 2011 | Bernina 1008
Bernina 1530 Inspiration my needle goes up and down thank you for helping
It is suppose to go up and down, that is how it makes stitches in the cloth..
Jan 15, 2011 | Sewing Machines
Sewing Machines Logo
186 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
