Question about Kodak EASYSHARE 5100 All-In-One Printer
I cant get the printing settings to change. all the print is distorted.
Why does my Xerox Phaser 5500 print distorted watermarks?
Click caret ro right of friend's post, click unfollow without unfreinding.
Feb 26, 2015 | Xerox Phaser Office Equipment & Supplies
My computer cant print to the wireless printer
An update may have corrupted the driver or changed the configuration. Resort to your owners manual for the computer and set up the wireless printing option again. I'm not a fan of wireless printers because of this issue.
Dec 12, 2013 | Kyocera FS-1118MFP Laser Printer
I have a canon MP630, for some reason the blue cartridge wont print. Was full and not printing so i changed it and still nothing. I have been using generics ever since i bought the printer without a...
I've had the same problem with my MP630, and have tried everything to fix it - still not working properly. I've washed the print head, changed settings, changed printer drivers, upped the cyan on my preferences, but still get poor quality blue, which in turn skews all other colours. Can anyone help???
Aug 24, 2010 | Computers & Internet
Prints only high quality , was printing a few pictures but cant get it back to normal setting
The settings in the printer driver over-ride settings selected from the printer. Drill down in the driver to find the setting you want and change it from there.
Apr 13, 2010 | HP Designjet Z6100 InkJet Printer
When I print from excel the page comes out blank
ok... here are some general tips... in your print driver make sure that it is set to spool documents... it gathers everything and then prints... make sure the print driver isn't shared from a server... servers are famous for distorting excel printer communication.... it isn't the konica... its a print driver excel conflict...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Mar 11, 2010 | Konica Minolta bizhub C250 All-In-One...
Distorted Printout
Causes for distortion or blurring
Cause
Solution
Transfer unit is defective
Replace the transfer unit. Calibrate the printer after
replacing the transfer unit.
Secondary-transfer roller is defective
If it does not rotate smoothly or is deformed, replace the
secondary-transfer roller.
DC controller PCB is defective
Replace the DC controller PCB. Calibrate the printer
after replacing the DC controller
Sep 11, 2009 | HP LaserJet 3055 All-In-One Printer
Bad photo quality after changing drum
your laser printer
1) print color quality is now distorted that means print skew (technician called)
2) print tint means the print color not enough density,
3) print mottle means print dirty
you may try
1) print distorted--- find out the skew adjustment from your printer manu, it is adjust the image before transfer to the drum.
2) print skew could be happened when the drum replace install not very accurate, so install it more carefully.
3) print tint---you may increase print density from the manu, not fix,
4) print tint---the toner caridge near life cycle or using the less compatible toner. so you have change the quality toner or cartridge (if near life cycle) to improve quality photo print
5)print mottle---toner quality ? or cartridge near life cycle also cause print dirty paper,
Feb 08, 2009 | Konica Minolta magicolor 2300DL Laser...
Cant make prints lighter or darker
There are two ways to do this. One is to change settings in whatever application your are using. Increase your font size or bold your font (if you're talking about a document.)
The other way is to change your printer properties. Go to your printing preferences (from your print dialog or from Start->Printers and Faxes->right click on Lexmark 5400 Series->select Printing Preferences) and increase your Print Quality.
Steve
Jan 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
Can not print in black and white. Everything is printing in color red. cant find setting to change to print in black and white
On your windows desktop, left click on START. Left cllick on CONTOL PANEL, then left click on PRINTERS. RIGHT CLICK on your printers icon. On the drop-down menu, left click on PRINTING PREFERENCES. On th MAIN tab, look for a checkbox that says GRAYSCALE PRINTING, MONOCHROME PRINTING, PRINT BLACK ONLY, or a similar phrase for B&W printing. Check the box, left click APPLY, then OK. Print a test to confirm.
Aug 18, 2008 | Office Equipment & Supplies
Kodak EASYSHARE 5100 All-In-One Printer Logo
20 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
