Question about LG DLEX2801R Electric Dryer
The lint filter does not quit fit all the way down into its assembly. The corner that sticks up is catching clothes and breaking straps.
SOURCE: my front load samsung dryer destroyed my clothes
ours did the same thing and it was caused by lint build up in the track where the screen goes into. It was tough to vacuum out but I made a thin hose that would reach down to the bottom and scrape and vacuum out the hardened lint.
Posted on Aug 14, 2010
SOURCE: The lint filter does not fit properly in the lint
We have the same model and experience the same thing. The way I fix it is to remove the filter, then with a flash light I look down into the lint trap. You will notice that lint has built up in the track where the lint filter sits. I use a wooden skewer to run along the track and lift out the lent. Hope that helps
Posted on Oct 14, 2011
  • 77 Answers
SOURCE: Our dryer lint trap won't go down all the way and
It may be backwards. But the first thing I would look for is if there is lint caught in the shute keeping it from going down all the way. If it is a newer model there is a lint screen sensor that may have come unattached and keeping the lint screen from going down all the way. Good luck.
Posted on Apr 20, 2009
  • 2976 Answers
SOURCE: lint trap doesnt fit in slot completely evenly
Remove the trap and look in the hole and see what is keeping it from going in. If the screen is damaged, replace it.
Posted on Jun 04, 2009
arikrom
  • 528 Answers
SOURCE: The plastic lint filter does not fit properly
if the unit not look damage then the filter hosing need to be replace but bout unit can be replace and the parts can bought in sears parts
Posted on Jan 02, 2010
My kenmore elite dryer that i bought 2 years ago lint trap corner is catching my clothes and tearing them. we had it replaced and its doing it again. I am tired of messing with it. Please help.
don't know if you already had this fixed,usually this is caused by not having your dryer cleaned out,the lint builds up inside the duct that the lint filter slides down into and has to be removed and cleaned out.also in some of the kenmore dryer ducts there's a metal clip inside the duct that can come loose and hold the lint filter up.these are the two most likely causes for this to happen.
Sep 23, 2013 | Kenmore Elite HE4 Electric Dryer
There is lint down in the "basin" below the lint filters and I cannot reach it to vacuum it out. I empty the lint screens after each and every load but this has built up in the bottom in the stainles
unplug it,remove the bottom panel,pull out the lint filter,you'll see the metal duct that the lint filter slides into,remove the 1/4 inch screws that hold it in place and remove it and vac it out,if you have a shop vac you can blow the lint off of the motor and blow all the lint in the back of the cabinet forwards and then vac it up,this way you don't have to pull the dryer apart to clean it,you should do this once a year so you don't have any problems with the dryer and your clothes will dry on time,also you should clean out the vent line,pull out the dryer,remove the vent line,if it's a long run stick a leaf blower into the vent line and blow all the lint in it outside,first make sure you don't have a cage or anything that will catch the lint,if you do remove it and don't put it back then go inside and blow out the line.this happens to every dryer even if you clean the lint filter every time.hope this helps and good luck with your dryer
Mar 30, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Lint filter on LG DLEX2901V sticks up in the corner and catches clothes
Look familiar? LG dryer model DLEX3250W. Lint frame does not fit the slot anymore. NOT BECAUSE OF EXTRA LINT it's because the frame is warping.
Dec 07, 2011 | LG DLEX2901V Dryer
The lint filter does not fit properly in the lint trap. The corner of the filter catches an item of clothing and twists it. I have to check it several times to clear the item away. I assume this...
Aug 21, 2011 | Samsung DV448AEE Electric Dryer
We have had a consistent problem with our dryer. The lint filter eats any staps in the dryer. I have found straps from bras, tops, and belts twisted around the lint filter. They get caught on the edge...
sound like front felt glide assy # upper felt seal part #134440200 lower felt seal #134134700 u can order these from sears.com
these componets support the front of drum and when felt wears away then clothing slips in gap and when dreyer tumbles clothing gets snagged in gap and tears clothing and leaves black scuffs
Jan 31, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Ijwant to dry my cloth but when i turn on it appear check filter how i am going to fix
You should empty the lint filter. The lint filter catches all the lint from your clothes and will need cleaned occassionally. I clean my lint filter after every load. Towels usually clog the filter faster than other clothes.
Aug 07, 2010 | LG DLG5932W Gas Dryer
The plastic lint filter does not fit properly anymore. Clothes with straps are now being caught and tangled causing the straps to break. My dryer is only about 1 year old.
Jan 02, 2010 | Dryers
Lint trap doesnt fit in slot completely evenly
Jun 04, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Our dryer lint trap won't go down all the way and is catching our clothes -- ruining spaghettis straps, bras, etc., twisting everything and catching our clothes on the corner of the trap.
Apr 19, 2009 | Dryers
My lint filter assembly is broken. I was drying a small load of clothes and the lint filter got tangled with clothes and came out into the drum. The dryer was stopped when I found this situation. ...
The drum should turn either direction. Part of the filter must be catching in the belt at the drum or motor when turning clockwise. CCW would push it out away from the belt so no pinching.
May 29, 2008 | Amana Dryers
LG DLEX2801R Electric Dryer Logo
889 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
