Question about HP Computers & Internet
Pavilion zd8000 battery will not charge charging indicator light flashes and the mains light remains constant. Renewed battery, tried another mains adaptor still will not charge. Laptop works whilst connected to the mains.
  • 57 Answers
Try cleaning the battery contacts. It's possible some dirt is keeping it from connecting correctly. Does it work with a charged battery placed in it and unhooked from power? If not, there's some issue with that internal circuitry.
Posted on Aug 04, 2008
    Problem Solver:
  • 9 Answers
Sounds like the battery may be bad. I would first suggest trying a replacement battery and see if it will charge if so problem solved; if however a replacement battery (that is known to be good) still does not work it is possible that your battery charger on your laptop has gone bad, which is possible but very rare.
Posted on Aug 03, 2008
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
HP ZD8000 won't power on
have you tried this with the battery removed from the laptop?
Oct 02, 2009 | HP Pavilion zd8000 Notebook
HP zd8000 will not boot on battery
If every thing is correct ( the Battery, the AC adapter, etc ) then also the Power light is not turning on, then somewhere the power is not transmitting. The laptop must have a internal connection Breakage. Oh, I saw that you didn't mention AC Adapter. Have you checked it. Also check the the Control Board of the Laptop. Better you give it a Servicing.
Thank you Sir, Have a nice day.
Sep 25, 2009 | HP Pavilion zd8000 Notebook
HP zd8000 will not charge battery or run on power cord
check the dc jack probably is loose that cause the batterie dont get charge
Aug 13, 2009 | HP Pavilion zd8000 Notebook
Which indicator light on my mobil line battery charge complete
the green light should remain on when fully charged.
Regards
GeWiz.
Jan 11, 2009 | RTO Mobil Line Mobility Scooter Chair...
No problem? ?? HP dv8230 status indicator lights flashing.
I believe this would mean that your battery either has a low charge or if you have the AC power cord plugged in, it could mean your battery is bad and won't take a charge
Jan 05, 2009 | HP Pavilion dv8230us Notebook
HP Pavilion ZD8000 - Battery
i have the same situation. The workround I use is this...
Method 1
Start the laptop with the mains disconnected
Once Widows is running plug in the mains adaptor
The battery will charge correctly, the laptop will run on the battery if the adaptor is unplugged
Second method if the battery is flat
Start up with the battery removed
Once windows has started - plug in the battery
I have found no permanent solution so I use method 1 mostly
Nov 28, 2008 | HP Pavilion zd8000 Notebook
Battery and/or charging problem with zd8000
Hi, Yours might be a case of a batch of factory defect batteries. Bring it back to Circuit City and ask for a replacement but ask if you can get from a different batch. If they will not agree, show them the problem and try it in their presence. Though you may also ask for a check up of the output of the adapter and its charging/powering capacity. Another thing you can try is to power up then shutdown your laptop normally (even if have to use AC). With the PC off let the AC adapter focus on charging the battery for a couple of hours at least (overnight preferably). Then try again using the PC battery only. If this does not work guess your back to Circuit City. Good luck and kind regards.
Aug 30, 2007 | HP Pavilion zd8000 Notebook
HP pavilion zd8000, Battery not charging
The problems with the HP Pavilion (Particularly the ZD8000) are sadly well-known by HP. It's not a problem with the battery or the charger or anything you can easily fix. The problem is heat. If you search long enough, you'll find hundreds of people with three problems: 1) the battery stops holding a charge after about 8 months, they buy a new one and get the same problem; 2) certain keys stop working on the keyboard, they remove the battery and the keys work again; 3) permanent lines start to appear on the display and never go away.
Unfortunately, there is nothing you can do about these problems with the ZD8000, except stop using it as a laptop and ditch the battery. I have been problem-free since I ditched my third battery and just use it with a power cord.
Last year, I filed a formal complaint with the Better Business Bureau regarding HP's failure to acknowledge this problem and recall the machine. Each time I called service, I was instructed to follow the battery initialization procedure. All this does is allow support to get rid of you for 24 wasted hours, after which you have to call again and talk to some one new who tells you to do the same thing. The problem is, the procedure fails because the battery won't hold a chage in the first place. If you get to the end of the procedure with them after wasted days, they tell you to buy a new battery.
The HP ZD8000 is defective and never should have been released with a Pentium 4 processor. It's too hot and fries the battery and damages the screen.
Jan 26, 2007 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
108 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
