Question about Maytag Dryers
I have a maytag MED5820TWO. The blower or drum drive will come on. The heating element is hot and even stays on when I open the door, Could a bad door switch allow the element to heat up but not allow the drum or blower to work?
5 Suggested Answers
Oceti
  • 51 Answers
SOURCE: dryer spins but no heat
Did you check the power coard where it connects to the dryer? Start at the source. Make sure that you have at least 110v on each line. The dryer will tumble on 110v but requires 220v to heat. If you have 220v then check the t-stat and thermal cut-out on the blower. Check all wires for loose or burnt terminals. If all that is good it may be a bad motor or timer/control. I'm happy that you have a meter.
Good luck.
Posted on Dec 17, 2007
  • 7 Answers
SOURCE: Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Posted on Jan 21, 2009
erpaalai
  • 999 Answers
SOURCE: Kenmore 80 series dryer. The drum will not turn.
You Take the front off.Screws under endcap trim ,flip console back. Remove screws along vack and top slides forward. take bottom panel off and then door and front panel.
eric
Posted on Jul 04, 2009
repairman45
  • 130 Answers
SOURCE: My dryer is not heating, the drum runs but no
Not by just looking at it. You will have to test it for continuity from end to end.
Posted on Dec 18, 2010
MayTag Bravos XL-panel does not light up. But the drum light does come on when door opened. Could this be a failed heater element? I have replaced this before.
no if the element was bad you wouldn't have heat it would still run.if you write back open the door look around the opening where you put the clothes in and send the full model number
Dec 16, 2017 | Maytag Dryers
I get code E6 and my Maytag dryer keeps stopping
BAD MOTOR WINDINGS OR DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Apr 19, 2015 | Maytag Dryers
Element turns on even if door is open. at end of drying cycle drum shuts down but element stays hot
Your problem is usually caused by a bad/broken heating element. What happened is the element broke or burned apart at some point and the broken end has grounded against the dryer body. Instead of the power going through the control system and shutting off the heater, the power is going through the broken part of the heater and then to the dryer body with no shut off point like a direct circuit. Probably needs heater replaced. Could also be one of the controls stuck but usually the 1st problem I stated..
Mar 28, 2015 | Maytag MED5770TQ Electric Commercial Dryer
I have a MEDC400VWG drier.Woked fine yesterday. Put clothes in it today. Pushed start button. nothing happened. Smelled somthing getting hot. opened drier. Heating coils lit up. (with door open). Turned...
Sounds as if the motor centrifugal switch is stuck. Check to see if lint built up around switch or centrifugal mechanism on motor shaft. Rap switch with the handle of a screw driver hard but don't break it .
Nov 01, 2010 | Maytag PYE3300 Dryer
My maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
Oct 20, 2009 | Maytag PYE2300AY Electric Dryer
My dryer spins but it is not getting hot or blowing air. I think replacing the heating element and/or thermal fuse will solve the problem but what about the blowing air?
WHEN YOU OPEN THE DOOR THERE IS A SLOT WHERE THE DOOR SWITCH MAKES CONTACT TO LET THE DRYER RUN. TAKE A PLASTIC OBJECT AND HOLD THE DOOR SWITCH IN AND START THE DRYER DO YOU SEE THE ELEMENT GLOWING IF YOU DO YOUR ELEMENT IS NOT BAD THE BELT THAT TURNS THE DRUM SHOULD TURN THE BLOWER TOO.IF YOU SEE TWO BELTS ON YOUR UNIT GET6 BACK TO ME
Aug 09, 2009 | Roper RES7646KQ Electric Dryer
Dryer wil not get hot
The problem is most likely a blown thermal fuse or a bad heating element. The thermal fuse should be attached to the duct just inside the back panel. It is about an inch long. The thermal fuse and the heating element should have continuity, therefore they are simple to test with an ohm meter or multimeter. If either component does not have continuity, then that component will need to be replaced. Hope this helped, and good luck.
Jul 19, 2009 | Maytag Performa PAV2200
Motor not strong enough
The problem dosen't sound like the motor. Check to see if the drive belt is loose and slipping. This is the usual cause of the problem you describe. If not, the bearings for the drum may be going bad. The heating elements should turn off shortly if the drum stops so there is little danger of overheating.
Ray
Dec 15, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
