Question about HP OfficeJet 6310 All-in-One Printer (Printer/Scanner/Copier/Fax) w/USB Printer Cable , Retail
Printer not working
I have a hp officejet 6318 allin one printer. i can cannect the printer with power cord and printer is try to install but nothing movement in printer. after some time its showing cheacking catrages but nothing and cantinue say this message
    Scholar:
  • 169 Answers
Well all u need is a reset on the printer using the # and the number 6.Keep the buttons held down and the plug in the power cord.See if it works.
If you wannt any further support a technician can help you online for free.You can find free online technical support at http://tinyurl.com/m7ghqz
Posted on Jun 19, 2009
Press enter to alline cartridges
If you are getting Alignment failed or Align cartridge Error, It could be because of these possible reasons listed below.
1. Faulty Cartridge ( if you are replacing one now )2. Refilled Cartridge ( not filled properly )3. Cartridge Low on ink ( does not give printer enough ink to align the printer )4. Could also be Hardware Issue ( Most of the time the HP Printer has life time of 4-5 years )
First step,
Remove all the cartridges out and clean the electrical contacts ( golden Contacts ) with a lint free cloth and Re-install them again
It should go through the alignment process and complete it.
If it does not,
Try to access the Setup menu and under tools you will find Align Printer, Try this.
If the Cartridge ink is full or has adequate ink ( atleast 30% in each cartridge ), and the cartridge is not refilled, then the last option is to do a hard reset on the printer.
But Doing the reset your printer will loose network connection, all the printer settings and fax logs,
To do the Reset,
Disconnect the power cord from back of the printer ( while printer is powered on )While holding the # and 6 button at the same time, Connect the power cord back.Go through the setup process to re-setup the printer settings,If it still does not align the printer, You may give a try to install using new cartridge ( but i doubt, it could be the end of the printer.)
Call HP and check if they have any good offer or they can help you with aligning the printer once.
Regards,Suhail
Nov 13, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Lost instalation cd for hp 4355 allin one
You can download drivers for HP Officejet 4355 for any operating system from here also:
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 21, 2010 | HP Officejet 4355 All-In-One InkJet...
HP Officejet 6318 displays "reset
Go to this LINK.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 23, 2010 | HP OfficeJet 6310 All-in-One Printer...
How do you turn off sleep mode on the hp officejet 4500?
This no doubt violated the warantee, but I got tired of turning the printer around and unplugging the power cord etc.
So I got a cord switch I had (Ace hardware 31089, others will not doubt work) and installed it in the power cord per directions.
Now it is easy to reach behind printer and cycle the power with the power cord switch and thus wake up the printer.
May 20, 2010 | HP Officejet 6500 Wireless All-in-One...
Where can i go to download the software it did not come with disk
Go to the HP website. Click on the upport link. Lookup your specific printer model # and operating system you are using. Download the appropriate files and install. You should be all set. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 20, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Officejet 6310 won't turn on.
Ok try unplugging the printer for about 15 minutes and plug it back in that will reset the printer and it should work fine.
Let me know how it works out
Dec 24, 2008 | HP Officejet 6310 All-In-One InkJet...
Printer problem
That could be a signal of a problem. Reset the printer and make sure you get an OK light (usually solid green)
is the printer connected directly to the PC or is it a network printer?
Jun 13, 2008 | HP StorageWorks SAN Switch 4/32B Power...
Open Questions:
See all HP OfficeJet 6310 All-in-One Printer Questions
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
