Question about Citizen BL5314 52E WR200 Eco-Drive scyba watch
How do i adjust the time on my citizen eco-drive wr200 watch?
  • 73 Answers
SOURCE: Setting the time on a Citizen Eco-Drive Watch
Go to this link and pay particular instructions on how to find your watches movement or caliber number.
http://www.citizenwatch.com/COA/English/settings.asp
Posted on Dec 31, 2007
escapement
  • 2334 Answers
SOURCE: Citizen Eco-Drive Skyhawk JR 3060-59F
Paste this link into your browser and follow instructions:
http://www.citizenwatch.com/CUK/English/settings_int.asp?caliber=C650&interactive=C650
If this is not the correct caliber number, click on technical support tab in the same webpage and find the right one for your watch.
DO NOT FORGET TO RATE, PLEASE.
Posted on Mar 09, 2009
escapement
  • 2334 Answers
SOURCE: how do you adjust a stainless steel strap of a citizen eco watch
If there are screw on each side- you have to use two screwdrivers simultaneously. If not- read the rest:
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out. First you have to find out what sort of pins or even screws are used to keep links together. Examine both bracelet sides and find the side where pin ends have a groove. Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead. For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it. Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well. NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!! Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows. After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting. After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet. It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin. Make sure that pin ends are flush with bracelet. If needed- hit few more times. Job done! If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Sep 01, 2009
escapement
  • 2334 Answers
SOURCE: How do I manually set my Eco-drive wr200
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CITIZEN watch manuals. Rate me, please
Posted on Apr 02, 2010
SOURCE: My Citizen WR200 keeps resetting to the year 2016
My Skyhawk AT is showing the wrong date and the year is 2016. How do I correct this?
The factory has discovered a software anomaly in the calendar programming of the integrated circuit that affects some Skyhawk AT and other styles utilizing the U600 movement caliber produced in only 2007 for those watches receiving either the U.S. or Japanese time signals. Those customers receiving the German time signals or have pieces manufactured in other years are not affected. This anomaly results in the calendar displaying dates from 2016 even though the year is 2010. Rest assured no other production series, feature, function, aesthetic portion or other Skyhawk series timepiece is affected.
If your 2007 production Skhyawk AT shows the year 2016, we are ask you to send the watch for updating.
Once your watch receives the software update, there will be a small dot punched on your caseback in front of the serial number. Our goal is to have your watch returned to you in two weeks once it is received by us.
If you are located in the United States,please email us the following information so that we may arrange a prepaid shipping label with UPS for you:(customerservice_us@citizenwatch.com):
Your Name
Company (if you are going to return from your place of work)
Address (don't forget any apartment or suite number)
City, State, Zip Code
Telephone number
Email address
If you prefer, you may also call us at 800 321 1023 x4234 with the information. Do be aware that our telephones may be very busy so hold times could be longer than we would like.
Once the label is arranged, you will receive an email from UPS with instructions on sending your watch. Be sure to pack the watch securely in a sturdy box (do not send the original packaging or materials), tape the label to the box and submit the package to one of the many UPS drop off locations throughout the United States. If you are located outside the U.S, please contact your nearest service center for direction.
We appreciate your understanding and apologize for any inconvenience this may cause.
Posted on Aug 31, 2010
Pull crown out 1 click to set day/date, set to one day behind actual date... Then, pull crown out an additional click to move hour/minute hands around to set exact date by hour/minute a complete 12-24 hour revolution if necessary to get AM or PM accurate for the proper day/date. :)
Jul 05, 2014 | Citizen BL5314 52E WR200 Eco-Drive scyba...
Citizen eco drive U706
You can get the instruction off this link in PDF or VIDEO instructions
http://www.citizenwatch.com/en-uk/support/setting-instructions/
Jul 07, 2013 | Watches
Citizen eco drive watch is brand new, but the second hand doesn't move. Watch does keep time and date.
You should take the watch back to the dealer for exchange or refund since it would be under warranty, taking the watch apart will void your warranty leaving you unhappy with your purchase.
Dec 18, 2010 | Citizen BL5314 52E WR200 Eco-Drive scyba...
My Citizen WR200 keeps resetting to the year 2016.
If you haven't got instructions you can get them from you can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
If this does not help I suggest that you contact them and discuss your problem. The web site indicates that there a 5 year warranty on their watches. If this applies to your watch, then they should repair it free of charge.
Jul 15, 2010 | Citizen BL5314 52E WR200 Eco-Drive scyba...
Set Time Citizen WR200
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch here.
Apr 24, 2010 | Citizen Eco-Drive watch
Daylight saving time
You can get instructions from the Citizen web site.
Apr 13, 2010 | Citizen BL5314 52E WR200 Eco-Drive scyba...
Apr 01, 2010 | Citizen BL5314 52E WR200 Eco-Drive scyba...
Citizen BL5314 52E WR200 Eco-Drive scyba watch Logo
1,415 people viewed this question
Top Citizen Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
