I have a sharp aquos LC-C3242U i lost the remote so i bought a one for all urc-7931 universal remote but i find codes that work the volume and power etc but none of the codes will work for the menu which sucks cause i need to scan the channels or it will just stay on one channel
    Brigadier General:
  • 8,909 Answers
Http://www.2instructions.com/search.php?cmarque=CREST&modele=URC-11-4130%20B01
This may help
Posted on Mar 13, 2011
Have an AQUOS QUATTRON.. SERIES 108852008, MODEL.. LC-60-E 832 U, HAVE NO REMOTE, can i use a universal remote for it and how do i get the code?
The AQUOS TV manual is available at this link. It will give you the operations that the Sharp remote will do.
http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/LCDTVs/Manuals/tel_man_LC40_46_52_60LE832U.pdf
You can buy a Universal remote but that will not have all the operations possible.
Remotes One For All Global
The procedure to load the remote code for your TV will be mentioned in the user guide for the remote or you can select from this site depending on which model of remote you buy.
Mainstream 6 URC 7560 One For All Global
you can buy one through ebay
One for All Five Device Learning Universal Remote Control TV DVD VCR...
Sep 25, 2014 | Sharp Aquos Televison & Video
Why won't my LC-C3242U Sharp Aquos tv won't turn on
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time.
Sep 06, 2014 | Sharp Aquos Televison & Video
I have a Sharp Aquos LC-32D44U LC TV and I am not able to get a radio shack universal remote turn the TV on and off (or anything else) even though I have tried all the codes, auto set up and manuel set up....
I have the same model that quit working with its remote or any programmable one a found a solution here on FixYa. Turn off the TV and unplug it. Hold the power button on the TV for 10 seconds then plug the TV back in. My remote worked again by doing this.
Dec 31, 2010 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
No remote to my sharp tv LC-32SB24U need codes to program my remote...
I have a Sharp LC-32SB24U TV, I need the universal code for my universal remote.
Jan 16, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-C3242U power issues
Do you get any indicator lights at all, if you do, then the 5v standby circuit is working, if you get nothing at all, then the main power supply will be the first palce to look, blown fuse? capacitors?
Nov 06, 2009 | Televison & Video
Have Sky plus and the remote does not accept any codes I have got, so no volume control via Sky remote. Do you have the correct code for a Sharp Aquos 46" ? Thanks
please follow the steps below:
TV
RED + SELECT
TV
0093
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Jul 10, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How do I get the volume to work on my sky remote control?
SHARP TV
TV
RED + SELECT
TV
0093 (sharp code)
press the power button if this turns your TV off then press SELECT to save. If not press TV then POWER. repeat this step until it does turn your tv off remember to press the SELECT button to save the code.
Cheers
Little Dish Fitter
Sep 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
Jun 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
REMOTE CODE
i need the code for a sanyo!
Feb 18, 2008 | Televison & Video
Televison & Video Logo
311 people viewed this question
Top Televison & Video Experts
Electro Med Services...
