Question about Sanyo DP50747 50 in. Plasma TV
When u turn it on it has no picture or sound then there after it clicks on and off.
    President:
  • 1,654 Answers
This is another typical issue with power supply boards. You need to have a qualified tech look at this and determine which board is bad, but it points to the power supply, they get the hottest and burn out the earliest.
Posted on Mar 13, 2011
Just turned tv on when it made a pop sound, the picture goes out, then started clicking like an electric arc jumping sound. Now when I try to turn it on- no picture and all I get is this clicking/arc jump....
This is the starter relay, the powpping sound was the death of a number of capacitors on the power board and possibly on the sustain boards that control picture and sound. This is major surgery, not just a board swap job.
Cost of repair estimated is about $600.;00 for parts and labour If there is any extended warranty use it now.
Please rate my help++++Thanks for using FIXYA
May 20, 2010 | Televison & Video
No Picture but still has sound
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is 915P049010. you can find it here: http://www.discount-merchant.com/Mitsubishi-915P049010-Lamp-Replacement-p/mitsubishi-915p049010-lamp.htmHave a blessed one!
May 03, 2010 | Mitsubishi WD-57731 57" Projection HDTV
Tv will not turn on, just makes a clicking sound
Brother this is problem usually  when either the fly-back (picture tube transformer )or tube  voltage regulator  Transistor is damaged or the picture tube has a short
Best of luck
Aug 12, 2009 | Panasonic Televison & Video
Will not come on it only a clicking sound from part no. 0mron 0584H3
I had the same problem with my tv, same make and model. I first continuously turn on and off my tv manually until I could get some kind of picture. This procedure took maybe five minutes. I was able to get a fine picture and sound, as if it was brand new! Other things to keep in mind, try to eliminate dust build up as much as possible.. Hope this helps out...
May 21, 2009 | Philips Magnavox 27MS343S 27" TV
No sound or picture
your relay is turning off most likelt due to on of the stanby voltages being out of parameters I would check the low voltage regulators and the horizontal output transistors.
Jun 16, 2008 | Toshiba 50HX81 50" Rear Projection...
No sound, no picture. TV clicks on and off over and over.
You both have bad Flyback Transfomers.this is not a fix it at home problem .ThankYou for using FixYa. Have a Nice Day.
Oct 04, 2007 | RCA 32V430T 32" TV
No picture just clicking sound
with your model number manny have a defective flyback part number is 1-453-310-11
regards,
daniel.
Mar 31, 2007 | Sony KV-27FV16 TV
No picture and clicking sound only
This may be a power supply problem or a shorted horizontal output transistor shorted. The clicking sound is the power supply trying to start but can't because of the overload. Stargazer
Feb 17, 2007 | Curtis CM32020S 32" TV
No picture or sound
If you had a burning smell, well the board is toast. These sets are made to replace the entire board at one time. Before installing the replacement module, the picture tube should be checked. A defective picture tube ( such as a G1 short) may cause a failure in the power supply section.
Sep 07, 2006 | Zenith C32V36 32" TV
Sanyo DP50747 50 in. Plasma TV Logo
164 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
