Question about LG KU990 Viewty
KU990 Camera Flash Not Working
Well recently my camera's flash unexpectedly stopped working, its definitely set on auto & I'm taking shots in the dark yet the flash has ceased operation..
Phone is in pristine condition and never has been dropped...
My GF has the same phone and had a similar problem where it would flash when it wanted to but has recently fixed itself....
Please Help...
Any one had a similar experience??
  • 17 more comments
  • wefilmstuff Aug 16, 2008
    my flash has also stopped working without anhy dmage made to the phone.
  • duffs609 Aug 20, 2008
    I have just received this phone yesterday and i have not dropped it or caused damage and yet the flash wont work. I have tried taking the battery out like the Three website says but it doesn't work. I have tried putting the camera into party mode as someone suggested but still it didn't work. I have also made sure the Image stabilizer isn't on as the flash wont work when it is on but still my flash wont work. Any other suggestions?!  It seems quite a few people have problems with their flash on this phone.
  • jcwarrior Aug 25, 2008
    I have the same problem with the flash stop working. I have restored default factory settings but flash doesn't work. Any solution?
  • Anonymous Aug 30, 2008
    flash not working
  • Anonymous Aug 31, 2008
    Mysterious. Yes I have had the same problem! Still under its warrenty, so I shall be taking it back to the shop where I got it. Shocking
  • Anonymous Sep 26, 2008
    The same with my phone - flash suddenly stopped working without physical damage.
  • Anonymous Oct 02, 2008
    flash just stopped working!!! no point in having 5mp without flash!!
  • dj_reform Oct 06, 2008
    i got same problem as well as turning it self off when on charge it things it is connected to computer ans says mass storage device connected the phone is poo and i could get it repaired but will lose phone for god knows how long while they repair it does anyone know why the flash stops working if its just the light unit i will buy on and replace it myself
  • 3emmbabesx Oct 28, 2008
    my phone is 2 days old and my flash just suddenly stopped working i havnt dropped it or anything ? any help ?
  • met-cho Oct 29, 2008
    Hey guys ive had mine for 3months, flash woks but barely, is useless at night.
    Has anyone taken it back is it covered by warranty?
  • Anonymous Nov 01, 2008
    flash stopped working
  • Anonymous Nov 02, 2008
    i have the same problem after still bringing back the phone because of scum underneath the screen
  • tunefish Nov 10, 2008
    I've had mine for like a couple of weeks now, and discovered the same problem tonight. Flash stopped working for no reason. :(
    Where do I find the "image stabilizer" option? coldn't find it...
  • Anonymous Nov 16, 2008
    My flash stopped working after a month... And so did the flashes of 4 other ppl with the same phone and we've all sent them in under warranty... now we wait...
  • Zelbinian Nov 20, 2008
    ditto same here, flash has stopped working, no physical damage to the phone, had it for 4 maybe 5 weeks,
  • Anonymous Dec 06, 2008
    less than a week old and the same problem has happend to me...any help
  • Anonymous Dec 11, 2008
    same here
  • Anonymous Mar 20, 2009
    the same problem
  • diukol May 11, 2010
    Solution link . . . http://www.LG-KU990-Viewty.com
Use the Mode button on the screen and set the camera into night mode / Auto Flash. That gets the flash going again. Then it seems to work again in other (eg Auto) camera mode again.
I also changed my ISO from 100 back to Auto when I made the change from night back to auto camera mode. I don't know if this made any difference.
The flash seems to lock out if you set the flash to "always off" at any point, then go directly to "auto".
It's a bug. I hope LG will upgrade the firmware when they fix it and the others.
Posted on Nov 13, 2008
Hey guys (and girls), I had this problem and that's how I came here. I don't know if this is the solution, but ten mins ago it didn't work, then I took of the case and next to the micro sd words (indented into the phone) there is a small metal button, I just pushed that and it came back on. I hope this is the problem and that I've helped you, if not, well, at least mine is working for now.
take it easy.
ross
Posted on Jan 19, 2009
Use code... 3845#*990*... and factory reset the phone... may be its work for u....
Posted on Sep 06, 2010
Your electrlytic capacitor of 330v 10mf RUBYCON is BAD ! EXPLOSED !
Posted on Jan 19, 2011
    New Friend:
Bluetooth divice not found
Posted on Jan 20, 2013
    Problem Solver:
  • 5 Answers
To the owners of a LG Ku990 the problem with your camera light may just be that the light is blown or disconnected from the circuit due to the heat that emits from the phone from using it for awhile because I've noticed the when the red eye reduction is on it flashes twice and although some might not have ventured into the phone i was surprising that the makeup of inside this phone was similar to a digital camera. besides that some of the methods mentioned in the other solutions might have worked for others due to "fiddling" with the phone so firstly to the few owners of this phone check your local mobile phone repair guy and see if its really one of the two symptoms mentioned above and good luck
Posted on Aug 16, 2009
  • 50 Answers
When in the camera go through the settings and turn the flash on.
Or
Look in the user manual.
Hope this was help...
Posted on Feb 14, 2009
My sony cyber-shot DSC-H10 flash stopped working. The flash pops up like it is going to work, but does not flash. I can take pictures but with noflash. Can you help me?
You flash is in ' Flash forced OFF ' position.Press on the flash control button repeatedly until one of the four modes are selected.
1.Flash Auto - Flashes when there is insufficient light or backlight ( Default Setting )
2.Flash forced on
3.Slow synchro - The shutter speed is slow in a dark place to clearly shoot the background that is out of flash light.
4.Flash forced off - ( Your current mode ).The flash automatically pops up and strobes when using the flash.Close the flash by hand after use.
Jun 03, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
Flash is not working
Hi there make your camera in auto flash mode & take a snap in dark place. If the flash not work then you need to replace the flash tube. Thanks.
Jan 15, 2011 | Sony Cyber-shot DSC-T300 Digital Camera
How can you test a camera before use to be sure the flash sync is working properly.
Set camera up and aim at a blank wall. Place flash on camera, fire off test shots with camera set to flash sync speed and lens set to wide angle (eg 18 mm), ensure flash matches angle of lens.
You will probably have to turn auto focus off, so that camera will fire, after taking photo/s use review to ensure that you have a nice even coloured piece of wall.
Any problems either with camera sync problems or flash coverage will show up in the test shots.
Camera sync, will show as part of the frame only exposed, for example you may find a horizontal line approximately 1/3 to 1/2 of frame with a proportion of the frame dark.
If you have flash "drop off" you will find the corners of your frame will be dark, you need to ensure that your flash angle specified on the flash and the focal length of the lens match.
Hope this helps Ian
Jul 21, 2009 | Cameras
Flash does not work
Ok,
Flash unit is defective and needs to be replaced as per following part number... (if you have camera repair experience then can do it your self because electric shock risk in involve in flash unit handling)
A-1249-950-A ..ST BLOCK ASSY
Above part is available in Part Store.
Dec 26, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Lg viewty camera flash not working
This worked for me: I turned the ISO to 800 and set the flash to "auto" - even in quite bright light the flash still goes off so I'd definitely try this. To turn the image stabiliszer off, press the "unlock" button next to the shutter on the side of the phone.
Dec 02, 2008 | LG KU990 Viewty
Sonyy w55 flash works but shot come really dark
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Aug 21, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Everything is so dark!
If the camera is working properly with other lenses, then you have a problem with that lens. In M, you can set the aperture yourself, and the photos come out properly exposed. When the lens is set to auto, apparently it is going to minimum aperture and not responding to the camera's 'instructions'. The thing that makes me think so is that you say everything looks dark through the optical viewfinder. Normally the aperture stays full open so you can see and compose your shot, and only stops down to the correct aperture when you actually take the shot. I would suggest having the lens checked by an appropriate camera service shop.
May 29, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
Camera not taking pictures
The camera may be trying to tell you that your flash is turned off in Auto mode, but to get a proper exposure you will need the flash turned on. Try turning the flash on and see if that works.
Hope this helps!
May 20, 2008 | Canon PowerShot A540 Digital Camera
Flash is inconsistent
I have the same issue. One picture the flash is perfect the next there seems to be a "half" powered flash and the pic is dark
Dec 09, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Problems with Flash
Press Menu button
Oct 16, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
LG KU990 Viewty Logo
6,517 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
