My furnace blower fan is not working and theres a smell coming out as well. I found the correct motor and capacitor part no.s. How easy are these to change out.
  • 72 Answers
The problem you're facing here could quite possibly be more than just replacing a motor. You could have circuit damage which may be the reason that the furnace quit working. You can try testing the fan that is currently installed. Make sure it is working first before buying new parts. Determine the required voltage for your fan and supply that voltage to it momentarily. Do this while the fan is completely isolated from your furnace (unplug any leads from it to the furnace controllerboard) You may want to get assistance when working with electrical current so you don't accidentally cause harm to yourself and/or your furnace.
Posted on Mar 13, 2011
  • Robert Mar 17, 2011
    If you are getting voltage from the board than either the capacitor is bad or the windings on the motor have failed. If you follow the wiring diagram they are not hard to change out. Just make sure to take your time and turn off power to Furnace when replacing.
    Problem Solver:
  • 3 Answers
Generally if the motor has a bad burnt smell it has shorted. Does the wheel spin freely? If it doesn't then a bearing in the motor seized and overheated the windings in the motor. Most likely it would be finished. If the wheel spins freely then you might be lucky and just have bad capacitor. It helps the motor run. You could try letting the motor cool if it's hot by shutting the power off. Then when it is cool turn power back on with the fan switch on the thermostat in the on position. If your furnace has door switch push it in and spin the wheel with your hand quickly. If the motor works the capacitor is probably at fault.
Posted on Mar 21, 2011
I show voltage to the blower motor but it does not start when i press fan on the thermostat? Bad relays or bad blower motor?
Sounds like a bad motor. I don't know if your blower motor has an external starting capacitor and / or a running capacitor. If There is a starting capacitor and it's faulty , that would prevent the motor starting and turning.
Jun 01, 2014 | Honeywell R856B 1002 R856B1002 Fan Control
Blower motor will not come on
If the blower motor has correct voltage and not running it can be a capacitor, its about $5 to try it, otherwise a new fan motor is required. 22296134-wil0gxehsfojcry3vcxysbjd-5-0.png
Dec 19, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Blower on furnace not working
Make sure your circuit breaker hasn't tripped to your furnace. Make sure your door panel to your furnace is installed right. There is a door switch that has to be depressed to complete the circuit. Also turn thermostat to fan on and see if fan comes on. If those two things don't work it will have to be trouble shot by a respectable HVAC technician. Could be your Indoor blower capacitor, defective fuse on circuit board or defective circuit board or defective blower motor.
Dec 06, 2013 | Heating & Cooling
Ruud achiever 10 inside blower motor burning
Check fan cage to make sure it turns freely. Check voltage to IFM make sure it is correct for the application. Make sure the motor turns the fan cage in the correct direction. IFM will have high and low speed make sure when you change from fan on to auto that the motor changes speed. If you have an amp draw meter check to see when running the motor pulls the amp load it is rated for. Recheck all wiring.
Feb 29, 2012 | Ruud Matching Split Air Conditioner
I have an old Intertherm gas-fired furnace, Model MGH-055AB which ceased operating last night. It was quite warm when I arrived home, and when I set the heat up a little, began to hum, but the fan would...
Tom P's answer is generally correct: The motor start capacitor is usually not the problem. However, in some cases, particularly on older furnaces, where there were capacitors of certain make and production run will prematurely fail. This happened in March on a mobile home HVAC unit where both the blower fan and condenser fan motor capacitors failed open circuit. Both caps were of the same Mfg, and production lot.
Here is a suggestion (for you or an electrically inclined friend): Locate a substitute motor capacitor having similar Mfd (or MF) and Voltage ratings. Remove power from the unit. Reach into the blower squirrel cage and spin it to verify that the shaft is not frozen. Pull the wires from the existing capacitor noting color and location. Connect the wires to the substitute capacitor and secure it place. Apply power and turn on the blower. A no start? Motor replacement time.
Nov 08, 2011 | Intertherm P3RA-048K Air Conditioner
Furnace blower won't turn on... Forced air gas furnace was working fine for three weeks. Now: Turn themostat up Gas comes on, pilot light obviously working Box heats up for about 90 seconds Humidifier...
If it indeed started that one time for a short period then cut out, the first place that I would start would be the capacitor located in the blower compartment. The capacitor gives the motor the need kick to start, and often times stays in the circuit to help the motor run more effeciently. This could very well be the problem.
If you have the option to run the fan from the thermostat, turn the fan to the "on" position and see if it starts. If it does, then it is not the capacitor.
Hope this helps
PS Your are correct about the "sensor" turning the furnace off, it is called a high limit switch and is there for safety. It is an automatic reset device, and will reconnect power once it has cool suffeciently.
Nov 10, 2010 | Dayton Gas Furnace Heater
Fan starts and quits several times
I will give you my best suggestions based on the information that was provided. It sounds like the blower motor is trying to come on several times unsuccessfully and then the flame is shutting off. If this is the case, here are my best guesses.
  1. If the blower motor has a run capacitor, the capacitor could be bad and the motor is trying to start but is pulling too many amps and tripping out on the internal thermal overload. You will need a multimeter that is capable of checking microfareds to determine if the capacitor is bad. Capacitors are usually marked....you will commonly see a marking of 5uf, 7.5uf, 10uf, etc... Sometimes all you need is a new capacitor. These are not very expensive.
  2. The blower motor itself may be bad.
  3. If there is a fan switch, it could be bad. A fan switch has a set of contacts that are normally open that will close when the switch heats up and send voltage to the blower motor. These will eventually wear out and act erratically if at all.
  4. The motor may not be getting the proper voltage, this too can cause the motor to pull too many amps.
  5. The most likely reason the flame is shutting off after the blower fails to come on is because the furnace is tripping on the high limit switch. This switch typically cuts the 24 volt power to the gas valve.
I hope this helps!
Oct 29, 2009 | Goodman CKL24AR24 Air Conditioner
Ac comes on,but blower does'nt..nothing wrong with blower!!!
check the wiring at the thermostat has anyone touched it g terminal is for the fan
May 07, 2009 | Heating & Cooling
I have a rheem furnace. A week or so ago, we had a burning smell, and the furnace shut down while I was gone. When I came back, it did start again, but the smell was still there. I called a guy who came...
Your control board may have a problem. When the burner fires up, after a time delay of about 45 seconds, you need to use a voltmeter and see if the terminal marked H for heat has 120 volts coming off it. This voltage will be the power to spin the blower. If ther is 120 vac at terminal H then the blower motor or cap. is no good. If there is no 120 vac then you may have a bad control board.
Jan 03, 2009 | Heating & Cooling
Coleman furnace problem
Sometimes people replace the blower motors with a higher horse power. Has this motor ever been changed? I believe the original should be a GE motor
Nov 12, 2007 | Heating & Cooling
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
