Question about Tally T6212 Matrix Printer
Ribbon fault ribbon is ok - Tally T6212 Matrix Printer
How to fix Toshiba Regza LCD TV when half the screen with vertical streaks?
hi this fault sounds like a bad tab/ribbon fault, at top of the tv are ribbons connector to the screen, when one is faulty the heat makes them flex causing this fault, you can bond the ribbon down with a bit of rubber to stop it flexing, but this not a permanent repair as it is a screen fault. hope it helps
regards
shaun
Apr 24, 2014 | Toshiba 42HP66 42 in. LCD Television
Ribbon fault
Hold in the Feed button for 4-5 seconds, which causes the printer to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
May 08, 2013 | Datamax I-CLASS DMX-I-4406 Thermal Label...
Ribbon fault error
First of all sorry for the problem.
It seems to be a logic card problem . Kindly contact with lipi for replacement of the logic card.
Aug 16, 2012 | Tally T6215 Matrix Printer
Showing Ribbon Fault
hi
clean the ribbon then if still same error chang the ribbon
Jun 19, 2011 | Tally 6312 Matrix Printer
I have a Tally 6212. I'm using non Tally ribbons which is producing a ribbon fault. I'm told by my ribbon supplier that there is an override to keep the ribbon from causing the fault. Can you...
If the ribbon is causing the Ribbon Fault, they would not be very well made compatables I would suggest changing to one of the other brands available. I belive the T6215 senses the ribbon turning by having a silver strip stuck on a rotating disk on the back of the ribbon, if this strip is not present or is not being detected it will display a Ribbon Fault. You can check the ribbon to ensure it has a reflective strip by manually winding the ribbon and looking at the back side of the ribbon, you should see a rotating disk which is half silver and half black. If this disk is not present the compatable ribbons would not be that compatable. The T6215 does to have a fault over ride for the Ribbon Sensor on its own, you can only over ride all faults this may cause other problems as Paper Out, Paper Motion errors are also overridden. You can enable fault override in the following way; Press and hold down LINE FEED and ENTER for about 5 seconds untill the printer bleeps. Press and Hold down FORM FEED and ENTER for about 5 seconds untill the printer bleeps. The above actions enabls Fault Over rides temporarily if the printer is powered off or reset Thai setting will be lost.
Apr 21, 2011 | Tally T6215 Matrix Printer
White screen - how do I fix that
Hi i must answer at least 10 of these a day with the white screen problem,
first of all this is a very common problem with all flip and slide phones and even laptops and netbooks.
now the problem is to do with the data ribbon that connects the screen to the circuit board this data ribbon is a thin ribbon that has several single strand copper wires running through it now when you open and close your phone this ribbon bends so as it keeps the connection with the screen.
over time these copper wires become brittle and break and this is what giving you the white screen
the only way to solve the problem is to get this ribbon replaced now as its such a common fault then this makes the part cheap to buy and cheap to get fitted, how ever its not something you can do yourself as you need special tools to remove and refit the ribbon.
your best and cheapest option is to take your phone to a small phone shop and ask them to replace this screen ribbon for you its such a common fault and that makes it a cheap part to get replaced.
so if you want to keep using the phone then it means your going to need to get this part replaced once you have got this part replaced you will have no problems using your phone.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 29, 2010 | Motorola Mobility RAZR V3
My nokia 6085s screen just went blue. i can receive calls but i cant see anything on the screen. is this a common problem? and how do i solve it?
Hi, yes this is a very common fault, the problem is with a thin ribbon that runs from the screen to the circuit board in the bottom this thin ribbon has single strand copper wires running through it then when you open and close the phone this ribbon bends to keep the signal, now over continued use the copper wires become brittle and break.
now the good news is as its a very common fault with all slide and flip phones it makes the part itself cheap to buy and cheap to fit, it isnt something you can do yourself as it requires specialist tools but if you go to a small phone shop and not a big branded one they should be able to replace the part whilst you wait.
let me know if you need further assistance ok.
plz rate this solution as i have a load of unrated posts on my screen, thanks
Aug 25, 2010 | Nokia 6085 Cellular Phone
15 Volt CTL fail
Hi Serap,
If a fault condition occurs in the printer, the status indicator on the control panel flashes on and off, and the message display indicates the specific fault.
For the operator-correctable faults, After correcting the displayed fault, press the CLEAR key to clear the error message and status indicator and resume printing. If the fault message reappears, contact your authorized service representative.
If a fault is not correctable by the operator, you may try two steps to clear the fault before calling your authorized service representative:
1. Set the printer power switch to O (Off), wait 15 seconds, then turn the printer on again. Run your print job again. If the message does not appear, it was a false indication and no further attention is required.
2. If the message reappears, press the CLEAR key. If the message disappears, it was a false indication and no further attention is required. If the message reappears, call your authorized service representative at 1-800-243-3338.
Message Explanation Action 15V CTL FAIL* Controller voltage failure. Contact authorized service representative.
Call 1-800-243-3338
As far as software for the flash file is concerned , I have checked with their officaial sites , but they donot have any firmware updates.
Thanks
Mar 27, 2009 | Printronix Line Matrix P5010 Printer
Fault code c-31:22
your needs repair in mechanism..Fault given is undetected reel motor rotation .This can be caused by a bad captan motor ,pinch roller bad or bad LS chassis ribbon from upper cassette mechanism.If unit has old type (B) mechanism ,there is a good change LS chassis ribbon is bad .When cassette is inserted and pushed into mech .The latch for LS chassis wears down ribbon and causing a sensor fault ..
Dec 05, 2007 | Sony Handycam CCD-TRV208E Camcorder
SP Screen
I think it is the ribbon. unless you dropped it and the LCD is cracked it could be the connection in the back of the LCD. Usually LCD are very durable and can last.
Aug 07, 2007 | Nintendo Game Boy Advance SP Console
Tally T6212 Matrix Printer Logo
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
