Question about Cell Phones
How do I program the phone with new phone numbers?
  • 34 Answers
This is a difficult question to answer without the specifics of your cell phone, but in general, many cell phones have the same settings.
  1. Open your contacts on your phone.
  2. You should see an option such as "Options" or "More", click the corresponding button.
  3. Select "Add" or "Add Contact".
This should take you to the contact input screen.
Posted on Mar 13, 2011
I want to reprogram some numbers on AT&T 822 (21213)
1. Lift receiver, touch "program" (above number keypad, on the bottom left of programmed numbers).
2. Enter phone number (1-AC-Number).Touch button for quick dial station (e.g., Name of Person to Call).
3. Hang up phone.
4, Lift and touch programmed button to dial (new) number.
Oct 06, 2013 | Lucent AT&T Speakerphone 822 (21213)
How do I change the time on my Panasonic KXDT343?
1. From extension 101, press the PROGRAM key.
2. Then, using the number pad, dial *#1234 (Display shows SYS-PRG #).
3. Using the number pad 000.(Display: 000 DATE / TIME)
4. Press the SP-PHONE key (Display example:'93 Jan. 1 FRI).
5. Press the SP-PHONE key again (Display example: 12:00 PM 24).
6. Enter the new hour using the number pad.
7. If you need to adjust the minutes press the FWD/DND key.
8. Enter the new minutes using the number pad.
9. If you need to adjust the AM/PM press the FWD/DND key.
10. Press the AUTO ANSWER/MUTE key to select AM or PM.
11. When finished entering the new time press the AUTO DIAL/STORE key.
12. Press the HOLD key.
13. Press the PROGRAM key to exit programming.
Jan 11, 2011 | Panasonic KXDT343 Phone
How i can change extention number to new one (i have 4 telephones in house)?
This can be done through system admin programming. From the programming phone, press program key then **1234(1234 is the default system admin password). Enter 003 for the program code then enter. Dial the present extension number followed by the new extension number, then press enter. Press end or lift the handset to finish.
Dec 12, 2010 | Panasonic KX-T7735 Corded Phone
I have panasonic kx-t7730. How to set the intercom name and number?
Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
How do i add a new phone to an existing system? I have connected the phone & just need to assign an extension number for it so that the other phones can see the system, thank you
If you have installed it on a new extension, it already has a number. By default, on a TA-series system, the jack and extension are the same, so Jack 12 is extension 112. Quickest way is to plug the phone in and dial 0. The main phone rings and the display will give you the extension number.
To program the buttons, press PROGRAM the button and dial 1 plus the extension number. The lines should already be programmed by default, but they are 0 plus 01, 02, 03 etc. Press STORE after each button you program.
If you want to program ringing and line access differently than it already is, you need to look in the Programming Manual for the specific phone system. The Panasonic cabinet is going to be white with a silver tag or a model number stenciled or embossed on the case. Something like TA-824 or TA-624 would probably be your system model.
Carl
Dec 15, 2009 | Panasonic KX-T7730 Corded Phone
I need an extra line to ring on my phone
First, you'll have to know what the line number is in the system for the new line.
To get the line port number, on the set/s that the new line appears on press feature *0 and the the new line.
The display should say for example L025:LINE 05.
The port number of the example is port 025.
write the port number of the new line down for future reference.
Programming2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear& ring
press next key (lower right arrow)til you see the line port number you wish to program
The display should say line 0xx: appear only
press the Chng key till it says appear & ring
press the release key when finished
Sep 29, 2009 | Nortel Meridian M7208 Corded Phone
Do you havew to delete existing phone numbers in Clairity W-1000
Yes I did solve my problem. Just lift the receiver, Push program key, enter full number and push program key again, then push the button above the space you want to store the new number in and hang up the phone. Did not have to delete the old number. Thanks.
May 12, 2009 | Clarity Walker 1000 Hearing Impaired/High...
Programming Auto Dial Number
Yep. Those are speed dial numbers. They are programmed from ext 101 or the main phone. Without picking up the handset, press PROG **1234 and dial 001 and ENTER. Dial your 3 digit speed dial number If there is something there, it will be displayed. A speed dial number is stored with the trunk access code in it (usually 9) so if you're putting in a new number, include the "9" plus the number exactly the way you dial it. Dial your new number with the access code and press ENTER.
Number changed :-)
You can keep putting in a whole boatload of new numbers with this procedure.
Carl
Mar 16, 2009 | Panasonic KX-T7633 Corded Phone
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
2.4GHz Cordless Phone
just edit the programmed phone number.
select it from your list and then press the edit button beneath the display
Jan 11, 2008 | Uniden Cordless Phone
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
