Changed all cartridges on photosmart c6380 still have fuzzy green photo's
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 544 Answers
Do a printhead cleaning cycle and an alignment of the printer.
This might help in obtaining a good photo print.
Posted on Mar 13, 2011
HP Photosmart C3680 prints 2/3 of photo then white
hey its machanism problem, the belt provided to moved the head will be getting jammed dude to heat of the rolers built for drying the image printed on paper, check the belt and hot rods.
Mar 29, 2014 | HP Photosmart C6380 All-In-One InkJet...
My HP Photosmart C6380 all in One is now printing colour and black and white photos with a green/blue colour in dark/black areas of the photo replacing what should be black or gray. It never used to do...
To see which color is having an issue, go to printer control panel and select "settings" > Tools> Print report> Print Quality report. When the page prints out, you will see which color is the problem. After you have figured that out, make sure the problem is not with the cartridge.
If you see lines or missing colors, clean the printhead by removing it from printer(open cover, lift gray latch on the right side of the cartridges, remove cartridges and the printhead will easily slip out by pulling up)
then soak the printhead in half inch deep amount of window cleaning solution. Preferably warm. Let soak at least 3 hours. Dry out the printhead and wipe rear conacts from moisture and dirt. Reinstall into printer and see the results.
-Alex
303Electronics eBay Stores http://www.303electronics.com/
Jun 01, 2017 | HP Photosmart C6380 All-In-One InkJet...
Photo black ink runs out b4 black on HP Photosmart C6380 printer
The black ink cartridge is larger than the photo black cartridge and black is used in photos to make the darker colors. Black text takes much less ink per page.
Jul 17, 2010 | HP Photosmart C6380 All-In-One InkJet...
HP Photosmart C6380 - 0xc19a0023
This problem is impossible to troubleshoot by just typing in this little box. HP support has documentation on this problem for your model:
HP C6380 Ink System Failure
I hope this helps!
Dec 27, 2009 | HP Photosmart C6380 All-In-One InkJet...
My HP C6380 keeps saying missing or damaged cartridge error hp photosmart c6380 for the photo black only, I have replaced it several times, new ink...is there a way to reset?
There's a few things you can try. The golden rule is to unplug it for a few minutes and let it get amnesia. Every time you replace a cartridge, do you insert it right after removing the old one? You need to close the printer door for a minute after removing the cartridge before inserting a new one so the head will return home and try to detect new cartridges. It will then throw the same message, but it will help to reset any software issues that are causing the problem. If that doesn't help, make sure the cartridge(s) you're using are compatible with the printer, and make sure you're peeling the plastic film off the cartridge's metal area. Failing that, you can look in the manual or find yourself an option in the printer's menus to reset to factory defaults. That may also solve your problem. If none of that works, the printer is probably physically damaged and needs to be serviced internally by you or a pro.
Nov 25, 2009 | HP Photosmart C6380 All-In-One InkJet...
Printer offline. Please confirm this could be due to faulty cartridges as told by technician,( checked through remote control), and that HP cartridges are guarenteed for 90 days. Could I solve the problem...
If the computer is showing you printer offline, then its either the printer cable is faulty or the USB port, so can you change the cable and try a different port?
Oct 01, 2009 | HP Photosmart C6380 All-In-One InkJet...
Not printing full colour, photos come out green
Use the cleaning tools supplied with the HP bundle and use the cartridge alignment tools to sort out this issue.
Jul 25, 2009 | HP Photosmart C6380 All-In-One InkJet...
79 people viewed this question
jasbo
jasbo
