Question about Samsung DV337 Electric Dryer
I have a Model # DV337AER/XAC dryer it was working fine it still turns on but there is no heat no matter what setting is this something we can fix or what part might need replacing and what are we looking at for costs this dryer is just over a year that we have it we didn't get the extended warranty as we have had other appliances that have lasted for years PLEASE HELP
    Sergeant:
    Novelist:
  • 196 Answers
will either be the element or the thermostats. you should check the stats first. To do this remove the back panel that is protruding out of the back, this houses the element and the 2 small stats. Visually check the element and if it looks ok then test the 2 stats. Do this by using a multimeter on continuity setting or sounder/buzzer setting and place the probes 1 on each side of the stats and you should get continuity or a buzzer sound. If not you will need to replace both of them. Hope this helps
  • I have a Model # DV337AER/XAC dryer it was working - 9k=
  • They normally look like this. Either parts aren't expensive
Posted on Mar 13, 2011
Samsung Dryer dv203aes/xac will not heat. Drum is rotating and lint was cleared from exhaust.
Check the following:
1. Does it have 220 volts (yes it runs, but dryers run on 110 volts)?
2. Check the heating element and the safety thermostats located on the heat element canister. Low air flow from any restriction like lint build up or mashed ducting or blocked air exhaust vent cap can either trip the safety stats or burn out the element. Clean dryer and exhaust ducting thoroughly and replace bad parts before placing back in service. Poor air flow is the number one problem with "No Heat" dryer issues.
Sep 20, 2016 | Samsung Dryers
Model #dv203aes/xac. it lights up the controls but it just counts down not spininng or heat.
Check for goop gum or junk on the wet sensor inside the dryer under back side of filter. If something is blocking dampness, the dryer analog monitor on the pc will send power to the count down timer for energy savings.
Dec 30, 2015 | Samsung Dryers
Dv337aer/xaa samsung dryer it had a t0 code i replaced the thermister. now i start it and all i hear is clicking, no spinning to heat? what should i do helppppp
You may have not put the belt on properly. These have a belt switch on the pully. So if it's installed wrong it'll pop off the drum causing the unit to be idle.
Nov 07, 2013 | Samsung DV419AGW Dryer
No heat model dv665jw/xac
Element or thermal trip on element, you will need to test them with a meter, as to which one, But if thermal trip gone, why, could be element on way out.
Mar 18, 2013 | Samsung 7.3 Cu. Ft. Electric Dryer
Not heating
Is there power to your heating element. It is probably not working.
Feb 27, 2011 | Samsung DV328AE Electric Dryer
Hi, I have problems with SAMSUNG Dryer Model # DV665JW/XAC. It does not dry clothes at all. Could u please help!!! cheers, lucina
you probably have a broken wire in the heating element. located on the back of machine, top right corner, behind panel.
remove the two screws
Sep 01, 2010 | Samsung Dryers
Our model medt5870tw0 maytag dryer does not dry properly
First , remove the vent hose from the dryer to see if good air flow is coming out the dryer vent . If not , could have a bad blower wheel . If so , then check the vent hose AND vent to outside to see if blocked . A dryer will either heat or not heat . Since your dryer heats , try drying a load without the vent hose connected to the dryer and see if it heats fine (telling you , a vent problem is apparent . Sometimes a dryer is pushed too far back , kinking the vent hose also .
Aug 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 97591220 gas dryer spins but won't heat...
you have to relight the pilot or clean the oriface were the gas shoots out of could be both one problem caused the other.
Jan 05, 2009 | Dryers
Maytag dryer won't heat up
i am having the exact same problem with this model as well just happened 4 days ago.
Mar 18, 2008 | Maytag Performa PAV2200
Samsung DV337 Electric Dryer Logo
317 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
