Question about Cobra 29 LTD CB Radio
NOT RECEIVING ANYTHING BUT STATIC HUMS WHEN I KEY IT UP AND WONT CALIBRATE OR TX BUT RECEIVES WEATHER BAND PERFECTLY
  • 391 Answers
Hello from what you are saying it sounds like not enough power have you connected this to power supply with output voltage 13.8volts ,,yes well if you have the problem is with the voltage regulator you will need to have this replaced this would cause the hum unless you were using a battery with charger connected this would cause a hum aswell goodluck
Posted on Mar 26, 2011
Cannot receive weather channel information
Antenna connected? Station off air due to bad weather? Is the 'squelch' set to you hear static, then turn it back just to where it stops hissing? Try that and let me know.
Feb 21, 2013 | Uniden BC60XLT Handheld Scanner
Can only receive forgein channels
See the swection on "Listening to the radio" on page 24 of the manual...
http://www.retrevo.com/support/Onkyo-TX-SR500-Receivers-manual/id/365ag205/t/2/
You can switch the AM band tuning steps between 9 kHz and 10 kHz.
The initial setting is 9 kHz. Please set the AM tuning step frequency to match the AM band tuning step frequency in your area.
USA and Canadian models 10 kHz
Other models 9 kHz
Press MEMORY while holding down TUNER.
Note: All the preset stations are erased when you switch the AM band tuning steps.
Oct 07, 2011 | Onkyo TX-SR500 Receiver
Shure ULXP4 with handheld wireless mic tx indicator and hum
There are many things that could be causing these types of symptoms. Try calling Shure and asking for their Applications Engineering Department. They can help you troubleshoot your wireless.
Jan 22, 2010 | Shure ULXP4 Receiver
Audio cuts of during graphics, Onkyo TX-SR706
I have a TX-SR505 and the same thing has been happening on mine since I bought it. I am also hooked up to a Panasonic Plasma, using the optical cable to the receiver. It's been perplexing me. I have noticed it typically during commercials, not during normal programming. If I turn up the volume on the Panasonic TV, I can hear the audio, so I know it's not a problem with the over the air signal. It must be something wrong with the reciever. Would love a fix to this!
Oct 06, 2009 | Onkyo TX-SR605 Receiver
Maximum Volume is set at 79 yet will max out at 60-65 depending on source, TV, Audio or DVD is anything wrong?
have you done the audessey setup or even changed the level calibration on your receiver? if so this would reduce the actual max volume on the receiver.
Feb 27, 2009 | Onkyo TX-SR606 Receiver
Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
May 06, 2008 | Onkyo TX-SR605 Receiver
Onkyo Subwoofer Pre Out Problem
May not necessarily be the out put, discontect the sub from the receiver and see if it still makes a hum, Making sure that you turn auto on, off on the sub woffer.
If it still makes a hum, then you have a earthing problem, you can get a earth filter put on your internal wiring in your home, or you can remove the earth pin on your sub woffer
Dec 13, 2007 | Onkyo TX-SR502 Receiver
Uniden pc 78 elite cb
Hi, This is a link to your old post re SWR 3....http://www.fixya.com/support/t180697-pc78_elite_cb As stated SWR 3 is too high, it should be 1.5 or lower. Fiberglass antenna are kinda notorious in setup and experience wise have not performed well or at all. Maybe you should try a different antenna (metal rod). Some good brands/models I have tried with very good results are K40, Hokushin, Comet, Oscar, Maldol, Daiwa. To check if you can receive, stick an ordinay length of wire ('bout 9' long) at the center of your radio's connector. RX should work (pls don't key the mic or TX).
Aug 12, 2007 | Uniden PC78ELITE 40-Channels Base CB Radio
Cobra 29 LTD CB Radio Logo
64 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
