Question about Caroma Home
Toilet loosing water in tank. Makes little hissing noise.
    Scholar:
  • 158 Answers
The little hissing noise is probably the valve slowly filling the tank back up and the water leaking out is probably because the flapper ball needs replaced. You can see it and get to it and replace it very easily, it is the black ball in the bottom of the tank, it has a chain going from it to the flush handle.
First make sure the chain has not flipped over the handle or gotten twisted, I have seen this happen and it does not allow the flapper ball to go all the way down and seat.
If you rub you finger across the top of the flapper ball and black (deteriorated rubber) comes off then replace the flapper ball, remove the clip from the handle, lift the fubber ears of the flapper ball off of the plastic posts at the base of the bowl fill tube, and replace making sure that there is not to much slack in the new chain, just adjust the clip on the new chain where there is just enough so that the new ball seats.
Make sure you turn the water off to the toilet before you replace the flapper ball your valve in the tank will open to fill the tank and it will run until you get a new flapper in place.
You can het a new flapper for a few bucks at Lowes, Ace, even Wal-mart
Posted on Mar 13, 2011
The toilet does not refill the tank to the water level line, as a result the float is about 20mm below the water line and the toilet is hissing 24/7. How do i adjust to make the toilet fill the tank to the...
The fill valve sounds if it is bad.Go to lowe's and get a fluidmaster fill valve(about $8) instructions included.turn off water and remove water from tank then disconnect supply tube,remove old fill valve install new,follow installation diagram,and the adjustment process to adjust the water level to correct level that should take care of your problem.
Jun 19, 2011 | Caroma toilet - water saving Sydney Low...
I have a Glacier Bay dual flush toilet that makes hissing noises sporadically. How do I make it stop?
I have a glacier bay dual flush toilet. I have had it since 2009. When it started the hissing noise I tried diff things to fix it. New water valve, new washer from tank to bowel.
The food die in the tank showed water was leaking into the bowl. As a result the water would try to keep filling the take every time a little water escaped making it hiss. Sound familiar?
Finally I contacted someone on line home depot and the glacier bay manufacture was the main people. You need a silicone washer that goes in the main center piece mechanism that lets the water into your tank. You need to remove the center main piece in your tank. at the bottom inside the mechanism itself is a washer the size of a coffee mug top circle.
You can only see it if you take apart the two pieces. Once this goes inside your problem WILL BE SOLVED. The manufacture sent it to me for free. She knew right way. What causes the problem is cleaner tablets in the tank or bad water. So that's it folks
Jan 28, 2011 | Home
Toto toilet - when flushing, it makes hammering noise. it started yesterday after it clogged and i cleaned using an auger. i am not sure if i damaged any thing when i flushed it with the auger spring still...
if you shut the water supply to the toilet before augering..the washer in the supply stop got loose and is causing water to be forced thru...shut the supply to the house off and remove the nut just behind the supply handle under tank and inspect..the water rushing thru supply is causing hammering..clogs and water supply have nothing in to do with each other
Dec 31, 2010 | Home
Toilet drains to a certain level every half hour then refills with a sqeaky noise,when flused it makes a very loud sqeaky noise.
May need to replace toilet flapper or entire flush valve. water is getting from the tank into the toilet which is causing this to happen.
Aug 31, 2010 | Toto Aquia II Dual Flush Toilet
Internal leak
I am not familiar with this particular toilet, but most toilets that have a tank have this problem when the rubber flap stopper does not seal and allows water to trickle through.
this is the rubber stopper that lifts when you use the flush handle, the fix was to use the handle and allow all the water to flow out and use a soft rag and clean the area that the stopper seals to, and you will also want to clean the stopper of any gunk that may have accumulated on it.
Mar 12, 2010 | Neptune FB1623 Toscane Toilet
My Toto Drake toilet makes a noise like it is gasping for air when the tank is refilling with water. The water flow stops and starts while this noise is being made.
just simply clean the auto switch,the noosle where the water comes out when the floater goes down everytime the tank is empty with water.
Jan 11, 2010 | Toto Drake ADA Compliant Toilet with...
Water is slowly filling up the toilet tank. It just make a loud hissing noise.
either the hose in the tank is plugged or the valve is not turned on all the way
Dec 18, 2009 | Fluidmaster Plumbing
My dual flush toilet fills up slowly how do i fix
Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
Hope this helps!
Nov 08, 2009 | Home
When the toilet has been flushed (push button)it makes a hissing noise and then overfills so the water is going away in the overflow pipe. it was fitted 3 years ago. thankyou.
on your ballcock assembly there is an adjustment device (usually a screw) you just need to adjust the water level so it does not go over the overflow and have the "running" sound. there is a reccomended level usually stamped on the tank or the overflow tube.
hope this helps
Jul 07, 2009 | Home
Flush
it sounds to me as though its the ballvalve not shutting off properly & when it does shut off the noise you hear is a water hammer, and my guessing is you have a water meter with a back flow prevention valve fitted so when the ballvalve shuts off the pressure exerted on the valve cant go anywhere due to the back flow unit so the noise is the water reverberating through loose pipe-work, annoying but not damaging
Dec 12, 2008 | Toto Toilets ST784S 12 Sedona Beige...
Home Logo
487 people viewed this question
Top Caroma Home Experts
Billy Detlefsen
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Caroma Home Expert? Answer questions, earn points and help others
