Question about GE Microwave Ovens
How does the top vent grill come off on a GE Microwave Spacemaker JVM1660SH01?
  • 67fbird Mar 14, 2011
    Thank you very much. I flat didn't see those screws when I looked before. After you pointed out part 71 that was all i needed
  • GE Master
  • 19,396 Answers
Hi.
The grill at the top is held by two Philips screws. There may be also clips at top and bottom. The grill is indicated in assembly part 70 in the diagram below. One of the screws is pictured as part 71. Only 2 screws hold the grill. The replacement should take no more than 15/20 minutes.
Click on the picture to enlarge:
Regards.
Ginko.
Posted on Mar 13, 2011
  • Ginko
    Ginko Mar 14, 2011
    You are welcome.
    All the best.
    Ginko.
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
Where is the fuse located in a GE Spacemaker II microwave model number J EM824_ _ _ ? I can't read the rest of the model number.
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should begin working.
Feb 09, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Trying to remove an old GE Spacemaker microwave JVM140-001 and can't figure out how to detach it. I do not have a manual or installation instructions.
On some of these old GE Spacemaker models, there are two long horizontal bolts at the top (R&L corners), accessed behind the upper grill. Remove the grill (four tiny screws), take out the two bolts (flat screw heads) that attach to the rear plate, and your microwave will come right down and out, providing you've removed the three mounting bolts on the top.
Dec 11, 2010 | General Electric Microwave Oven
How do i remove the grill on a spacemaker microwave oven
At our Web site, we have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes.
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward.
On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Having trouble removing front grill to install filter..removed top screws but grill will not come loose
Just installed a GE Spacemaker - my instructions tell me to remove screws and then slide grill to the left and then remove. Have you tried that?
Jan 05, 2010 | GE Spacemaker JVM1540 Microwave Oven
How to install charcoal filter in ge spacemaker microwave
top of the front grill there are 2 screws. remove those together with the grill. install filter in location underneath.
Dec 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave
yes there is. the fuse should be located behind the vent grill on the right side above the control panel. there may be a metal "grate" covering the access to it
Dec 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Microwave oven
ge microwave fuses are behind upper grill and behind right side grill
Jul 25, 2008 | Microwave Ovens
Cleaning vents
GE Spacemaker Profile X1800.
I would take out the grills and boil them, but cannot see how to do that.
Also, the GE stove top (Model JGSP44BEY) has so much baked on crud that I may never use it. I poured a whole bottle of easy off onto it and still cannot loosen it all. Same goes for the removable parts from the burners.
May 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave wont come on at all.
replace the fuse. You have to remove the top grill and then you will find it above the display
Dec 24, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
