My Whirilpool duet washer will not drain all the water in the spin cycle. its so bad now it wont drain with just a few pairs of paints.
  • Washing Mach... Master
  • 17,129 Answers
Please remove the drain hose from the tub and have the drain filter and the drain pump cleaned and back flushed thoroughly. Once this is done make sure that the washing machine is placed with the tilt slightly to the drain side so that the water collects to the drain outlet to fully drain off at the cycle.
Posted on Mar 13, 2011
    Sergeant:
    Novelist:
  • 196 Answers
You need to clear out the drain pump. if you should be able to access the pump from the front bottom by unscrewing and removing the filter. If not then you will need to tilt the machine back as far as you can so you can access the underneath. You will see the small drain pump. Have a basin ready to catch any water that comes out when remove the pump which is only held in by 1 or 2 screws and twisted out or pulled out. If it is clear then try removing the pipe that goes from the pump to the base of the tub. Hope this helps
  • My Whirilpool duet washer will - images?q=tbn:and9gcr-mxdah1b21c0ifcf_vq0bwvl71tkol_zfyfbxvft-36wcnhu6
  • 668 Answers
It sounds like a lid switch failure. The lid has to be closed for the motor to run on your washer. If the lid switch is faulty, it will act as if the lid is not closed.
You need to replace the lid switch.
Hope this helps.
Shane
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
Wont drain and tries to spin but wont stops flashes an F/ no numbers
Hi Edward:
Does this occur on all cycles? Usually a draining problem stems from an issue with the power supply, the position of the drain hose or a clog in the drain filter.
F variables (other than FH, F02, and SUD) just means a electrical problem.
Select PAUSE/CANCEL twice to cancel the cycle. Select DRAIN/SPIN if there is excessive water in the washer.
Turn off the water supply at the faucets, which are usually recessed in a square compartment in the wall behind the Kenmore Elite washer. Unscrew the inlet hoses that connect the water faucets to the washer. There is a mesh screen inside the hose. Make sure it is not clogged.
Uncurl the water hose if it is wound too many times, restricting water flow. Remove any kinks or bends in the hose that could be blocking water flow.
Re-select cycle and select HOLD TO START. If the problem remains, call for service, because could sound like perhaps the control board go to bad. Unplug it first, let it discharge (usually around 4 min) and then have a go at it again.
I hope that it will help to solve the problem, or will serve as a starting point to initiate a diagnostic work.
Feb 02, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont spin
Front load washer will not spin if the water is not draining out of the machine.
This would be the most common problem. The clean out could be cloged or the drain pump could be bad.
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Standing water in the washer hours after wash cycle completes
YES..I think drain hose @ sink too low Waste water from sink entering machine...Raise pipe....tie up ....
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool wshser-dryer: water won't drain, cycles won't start
You need to give more info in order for a diagnosis. Is this a compact stack unit or an all -in -one unit or an interconnected washer/dryer pair ? Is it front load or top load washer ? What do you mean by "dry cycle"? Is that dryer cycle or is it washer cycle without water ?
Usually when water cannot be drained it is a bad coupling connector on the motor drive, or a bad or clogged pump (small socks have been known to get sucked in an lodged in the pumps); in either case you need a good mechanic or a service person to handle the repair because it requires opening up the shell of the unit and getting to the motor/pump assembly.As always, disconnect the power cord before diving into the unit. Good Luck, Macgivor.
Sep 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet not functioning during spin cycle.
In front of the machine below the door you have a panel. There are 3 torx screws holding it from under. Unscrew and pull panel down & then towars you. You will see the pump assembly right in the centre big black hoses.
You need a pair of pliers & a shop-vac if you have one, or towels & a bucket. Use the pliers to unscrew the pump filter, it is white in colour. When you unscrew this water will begin to leak out; use towels or shop-vac to mop up. Do this till all the water is mopped. Remove the drain trap completely, you will find all sorts of junk, clean out completely & refit carefully, in reverse order.
Hope u appreciate this, u can rate me........
Feb 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Code to restart washer Duet
Answer Is the Delicate or Hand Washables cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such asDelicate or Hand Washables cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to keep delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was an Extra Low, Low or No Spin option selected?
Select the highest spin speed for the fabric being washed. If extra low spin or no spin was selected, the washer may not remove enough water from the load.
Were you washing one bulky item, such as a rug or large blanket?
Consider adding more items to help balance the load during spin. Select $FL-drainspin cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
Are excessive suds present?
Use only HE High Efficiency detergent. Using non-HE detergent or more than the manufacturer's recommended amount of detergent can cause excessive suds. The excess suds can cause the washer to run at a reduced spin speed, which will result in very wet loads.
See also: Why HE High Efficiency detergent is required.
Is the drain hose kinked or is the drain clogged?
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is your outlet voltage low?
Check electrical source or call an electrician.
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer indicates "5d"...
unplug.
open the bottom panel,3 screws on bottom
check the drain plug ,
remove the plug , mop up water ,
look inside for clogs ,
look above the ball,
look inside the propellers, spin the pumps propeller by hand.
reassemble.
close panel.
finally .
feel around the inside of the front rubber gasket for items.
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
