Question about GPX KCL8806DT 7 in. Portable Television
I have a GPX under cabinet LCD tv m/n KCL8806DT with a broken on/off push button. I wanted to turn it on one morning and pushed the button. Upon careful disassembly I discovered a small plastic piece on the back side of the button fatiqued and broke. Is there a replacement button available or a replacement board?
2 Suggested Answers
SOURCE: i have just installed a
I had the same problem. After running the channel scan off the menu keys,( which by the way didn't work the first time ) it did correct the problem, it also took several minutes to complete the scanning.
Hope this helps.
Posted on Feb 02, 2009
What size Machine Screws do I need to mount a GPX Under Cabinet TV?
Um, "machine screws"? Unless you have a metal fitting inside the cabinet for those to screw to, you don't need machine screws.
Assuming you do have the metal fitting, then take that fitting to the hardware store to get the correct screws (and perhaps nuts). How long? Measure the thickness of the bottom of your cabinet, add the thickness of the bracket(s), and get the next size longer.
Jul 09, 2015 | GPX KCL8806DT 7 in. Portable Television
Red light goes on and off
Needs the button put back into place. Look under the cabinet to see if there is an access panel below the switch, would go for all external controls. There would be a chassis with all the controls mounted to it.
Pull the plug before doing any repairs.
Look to see what it would look like in it's normal position. Something has moved out of place that holds the switch to the panel. Very tedious if you have to remove the whole housing.
Mar 14, 2013 | Toshiba 36A43 36" TV
Website to find parts for kcl8806dt
http://www.ebay.com/ctg/GPX-KCL8806DT-7-HD-LCD-Television-/54079401
Dec 27, 2012 | GPX KCL8806DT 7 in. Portable Television
Will not play Movies but will play Music
  • Media player is ultra-slim and mounts under cabinet to save counter space
  • LCD TV with 7-inch screen comes with 181-channel cable-ready tuner
  • TV screen swivels for variable viewing angels
  • Digital tune AM/FM stereo radio with station presets with dual front-firing built-in speakers
  • LCD display with blue backlight
  • Instant weather band
  • Digital clock timer, timer sounds to alarm or radio
  • Auxiliary audio/video input jacks
  • FM wire antenna
  • AC powered, built-in AC line cord
  • Battery back-up against power failure, remembers time
  • Uses two AAA size batteries for back-up (not included)
  • Soft-touch membrane remote control with direct channel select
  • Under-counter mounting template
check if your player can read mpeg, avi. divx, etc..
Aug 10, 2012 | GPX KCL8806DT 7 in. Portable Television
Broken on/off button
The spring is probably jammed or broken, just grab a small pick tool or something thin and small and pry it out, that should be a temporary fix if not then the front side panel has to be dissasembled and the spring or switch has to be replaced.
Good luck.
Jun 12, 2010 | GPX KCL8806DT 7 in. Portable Television
Sony radio/cd/clock under the cabinet. Lost
On the right side there is a push button switch labeled "Clock". It is springloaded so you have to push it in and hold it for a couple of seconds until the unit beeps and the hour position starts to blink. The volumn up and down buttons will control the changing of the numbers up and down and PM/AM. Pushing the clock button again will change the clock to the minutes position and you cann adjust the numbers up or down just like the hours. Push it one more time will lock-in the new time. Your done.
Jul 20, 2009 | Sony UNDER-CABINET LCD-TV DVD/CD CLOCK...
Model #KCL8806DT under cabinet tv- volume works fine -no picture on tv. Remote works with volume, will not chnge channels on tv. Channels will change if channel button on tv used. Menu button will not show...
the bad thing about your gpx tv is that it is made by apex and u cant get any parts for them they are a throw away units. now that i gave u some bad news now lets see if we can do anything to help u.u will not see a on screen menu if the lcd is not on ok. there is nothing u can do for this tv . it only sales for 70- $80.00 if the unit is under warranty u can send it back and get anotherone. i am sorry but when u buy and off brand unit this is what u deal with when it goes out.they donot make it so it can be repaired.
Oct 13, 2008 | Televison & Video
Clock display
Power/standby must be off. Press and hold "Timer/CLK" for 2 seconds. Use the up/down buttons just to the left of the Timer/CLK button to select 24-hr or 12-hr mode, then cycle through hours, minutes. In each case u can use the up/down buttons to set the time.
Aug 16, 2008 | GPX KCL8806DT 7 in. Portable Television
GPX KCL8806DT 7 in. Portable Television Logo
53 people viewed this question
Top GPX Televison & Video Experts
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
