Question about Car Audio & Video
I have a xhd6430 cd player.the face wont come on now but when you remove the face the red light is still flashing.it also will still take in and eject cds just wont come on
    Sniper:
  • 58 Answers
First thing I would recommend would be to check your fuses. If the fuses seem to be good, then pull the radio out and check the connection on the red wire. If the wires have a good connection then use a tester to see if the red wire is getting power. Remember RED is +. If you have a good connection and you know it's getting power then you may want to try and see if the ground (black) wire has a good connection. If it still doesn't seem to be working then you may also want to test the connection of the Yellow wire (the Yellow is also a + and should only have power when ignition is ON)
And if all the wires seem to be well connected, and you tested them all to see if they had power then it may be a problem internally with your radio.
Hope this helps.
Posted on Mar 14, 2011
My new dual XDMA450 stereo wont turn on. when i take off the face plate the red sensor light is flashing. this only happens when my head lights are on. what problem am i having with my stereo and why
Check your wiring connections. A similar thing started happening to me out of the blue. The unit would work fine for a period of time, and then just shut off for no reason, and I couldn't get it to come back on. The next day, it would come on again when I started the car and stay on for a while, only to shut down again. The red light behind the face plate continually flashed, regardless of whether the receiver was working. In my case, there was something off in my red wire connection. The unit would turn on / shut off when I moving the wires on either side of the connection. I redid the connection, secured it with electrical tape, and the problem has not reoccurred. If the red wire is not the problem in your case, try the black and yellow connections. These appear to be the wires that could cause this to happen. I can't explain why the power kept repeating the power on / off cycle, unless the wires were in just the right position to be moved / jostled slightly while driving. Hope this helps.
Oct 19, 2012 | Dual Audio Players & Recorders
Will not power on at all only get flashing light inside the unit with face off, any thoughts on this one?
make sure you have power going to the red wire. it needs to go to a switched power source.
Jun 10, 2010 | Kenwood KDC-MP5032 CD Player
No sound or lights
make sure the yellow wire has power all the time and the red wire has power when the key is on. Most likely you do not have power to the red.
May 19, 2010 | Boss 506CA CD Player
XHD6430 radio not fully powering on.
I had this same problem with this same deck, in addition to my sound going out for periods at a time. I solved the red light no-nothing else going on issue by pressing and holding the reset button for 5-10 seconds (on the unit, bottom left side - have to remove the removable face piece). Kind of frustrating still though, because every time I do that, I have to reset all my presets again. I had good luck with this deck in the begining, and now not so much. Customer Service from DualAV/Namsung is terrible - I don't think I would buy another deck from their company.
May 17, 2010 | Dual Car Audio & Video
My pioneer avic n2 will not turn on,but when the
sounds like you have blown your acc fuse or your risistor on your red wire on your radio has shorted out you can bypass this wire by choping it off it dose not affect the radio ,dvd at all.
Jan 17, 2010 | Pioneer AVIC-N2 Car DVD Player
Face plate wont turn on
On the faceplate back, there should be some metal contacts. Take a white (not pink, red, purple, etc) pencil eraser and clean the contacts on the faceplate back. You can take a little rubbing alcohol and a q-tip to the contacts on the player itself...just use a little bit. Let it dry for about 5 minutes and try again. If it has a reset button, you may try pushing it, however that will most likely reset the clock, radio stations, and any eq settings.
May 30, 2009 | Kenwood KDC-MP628 CD Player
The players red and green light keeps flashing and wont come on
THIS CAN BE SOLVED BY CHANGING THE MAIN POWER SUPPLY BOARD OF YOUR DVD PLAYERS. The main problem should be the Main Capacitor in the circuit. The safer side is to change the whole board.
Apr 23, 2009 | Televison & Video
Alpine CDA 7843E head unit
if this unit has a motorized face the ribbon cable is bad and will need to be replaced
Nov 25, 2008 | Alpine CDE-9852 CD Player
Daewoo Cd player
The car security is not connected to a head unit. It probably has a small blinking red light on it which blinks when you remove the faceplate and switch the ignition off. This is just an indicator which lets people see that the face plate is removed.
You can replace the headunit with any brand/model you want. It would be cheaper than buying a replacement faceplate.
Aug 03, 2008 | JVC KD-S5050 CD Player
Hidden coupled frequencies and 2 buttons not working
try reseting the unit if i dont work new face required
Aug 15, 2007 | Alpine CDA-9827 CD Player
Car Audio & Video Logo
91 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
