Question about LaCie LaCinema Premier 301816U MP3 Player
I changed my La Cie Premier TV set up by mistake. Now I can't play it on TV anymore. I still can access all my files from computer. Can you tell me how to fix this?
I have the same problem. did you already find out. I changed it my tv mode in HD.
Posted on Jun 17, 2011
How do I transfer from my la cie to my computer
Remove the USB module from the LaCie Write Card and plug it into a free USB port on your computer. Your computer should assign a new drive letter to the USB module (such as D: or higher letter). In Windows use Windows Explorer (on a Mac use File Manager) and you will be able to copy files from your LaCie USB module to your computer.
https://www.lacie.com/download/datasheet/DS_WriteCard.pdf
Sep 25, 2014 | LaCie La Cie 131057 Write Card Flash Drive...
My computer says la cie external hard drive is corrupted - is there anyway to recover my files? I need them!
You can try a program like http://www.piriform.com/recuva
But if your hard drive is damaged you will need data recovery help. This guy does it remotely and just works for donations http://FreeDataRecovery.us
Jul 20, 2011 | LaCie 500GB Rikiki USB 3.0 Portable Hard...
How do i transfer my data from my old la cie 80 gig 107443, to my new la cie 250 gig 300770? both boxes look the same, with the same connections [firewire, usb, 2 others].
Connect both drives to the computer at the same time. If you don't have enough USB ports, connect one to a USB port and the other to a Firewire port. Open a file management window (Explorer in Window, Finder in Mac OS) for each drive. Click and hold the left mouse button (only mouse button on most Mac models in the window for the 80 Gig drive and drag across several folders/files to select them. Release the mouse button, then click on and drag the selected group to the new drive window. When this copy operation is done, repeat with another group of files.
You could select (-A or -A) and drag everything on the old drive at one time, but sometimes the system will bog down on copying large amounts of data (greater than 4-8 GB at a time).
Mar 11, 2011 | LaCie (300770) 250 GB Hard Drive
My external La Cie 500Gig HDD has worked well for 3 years or more. Now when I connect it (via USB as aI have always done) ..The following happens: 1 I see the drive usually but not always under "My...
your drive has failed at either the power supply level or internal hard drive level.
First, please verify your power supply. When plugged into the power outlet, it should be silent. A defective power supply will hiss or have a high pitch noise to it. If it is defective, replace it and check if the issue is resolved.
If the power supply is silent, one or both of the internal hard drive is failing. If no data is needed, you can either replace the defective one which you will have to isolate by connecting the internal hard drives to a computer or with another enclosure and running a block scan software like hdTune which is free to download. The other option would be to scavenge the healthy drive and use it in another enclosure or inside the computer directly.
If you need the data and the problem was not the power supply, you will need to contact a data recovery center.
Regards,
Jan 07, 2011 | LaCie Big Disk 500 GB Hard Drive
Can't find hard drive on computer anymore. Blue light constantly blinks on Lacie
My LaCie drive was not showing up on my Mac, and making a soft clicking sound ....I thought i was in for expensive data recovery and worse...But I met a guy who told me that La Cie have had a lot of trouble with their POWER SUPPLY and that i should try their customer service. I did, and after a round iof idiotic scripted replies I got to a smart CSR who sent me a NEW power supply. Hey Presto! The drive is back and working perfectly, no data lost!!!
Nov 26, 2010 | LaCie (300770) 250 GB Hard Drive
La Cie (500 GB) icon not showing up on desktop
kcrosbie
If you are having trouble with the drive it is possible that the USB controller on the drive failed but the drive its self should be fine.
I would try the drive on another computer to see if it detects properly. Sometimes if the drive gets stopped improperly this can cause detection propblems but connecting it to another computer will force a scan of the drive that will repair any corrupted files that may be on the drive. Also check to see if the drive shows in disk management. The links below will show you how to check this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
If the drive does not show up in disk management and the drive is not in warranty I would recommend opening the drive and connecting it directly to your computer to access the data.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jul 05, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Help transferring files from computer hard drive to La Cie
Well you can ONLY transfer/Move DATA as Programs and Documents & Settings and User Directories, cannot be shifted at all. So It is only the Files and Data that can be Moved off a drive. To gain space back, Right Click on the HDD, go to properties, in properties Under the general, tab the first window, select disk cleanup, remove everything in those boxes and after, that look under Tools tab, & do a disk defragment. This may get you space back. If not you may have to get a new bigger drive, and clone your old drive, then install the new drive and reinstall the Cloned image back onto the new drive?
Mar 30, 2010 | Computers & Internet
I can't get my cd's I recorded on my sony dvd player
Check file extensions of files on your recorded cd's. Add file extension to Roxio, Windows Media player and check your drive settings.
Apr 22, 2009 | Sony DRU840A DVD-RAM Burner
WMP says it cannot access the file,might be in use,proxy settings
Windows Media player has limited options for playing different formats of file. But it can be corrected. Try download the full CODEC pack. You can get it free, but always choose the advanced options from the download site, as it might try and change or add new browsers or other software.
Once installed it should play any file.
Jul 05, 2017 | SanDisk Sansa Clip MP3 Player
LaCie LaCinema Premier 301816U  MP3 Player Logo
231 people viewed this question
Top LaCie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a LaCie Audio Player and Recorder Expert? Answer questions, earn points and help others
