Question about Vacuums
Hello My vax powa 4000 won't deliver the cleaning fluid to the carpet shampoo head. Both lights are on & the tube from the from the valve to the head blows through OK whereas the internal tube will not. Can the valve have failed shut? If so how do I change it? Look forward to hearing from you Regards, Russ Wardell
3 Suggested Answers
SOURCE: vax carpet shampooer wont release shampoo
if you unscrew a bit on the base that allows you to take off the brush, you will see a black plastic strip with very small holes in it. These are where your shampoo comes out of. Take a needle and re-pierce these holes and it should work again. I have just sorted mine out. good luck .
Posted on Mar 08, 2009
ukvacfan
  • 328 Answers
SOURCE: how do you use vax 2000 to shampoo carpets. do not
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Posted on Jun 19, 2009
I have just bought a vax vcwrs700 carpet shampooer at a garage sale. With it came a bottle of bissell x2 carpet shampoo. Woul you know how much shampoo I should know please?
probably a cap full from the bottle
make sure that you use the suds restrictor liquid as well or the suds will come up in the bucket and block of the vacuum flow
Oct 24, 2016 | Bissell Vacuums
How do I get the Shampoo solution tub unclogged so it mixes with the water to clean my carpets.
You can try adding hot water, but your best bet is to remove the tank and hose and flush them well with hot water to clean them out.
Jan 02, 2015 | Bissell Brushroll Proheat 2X 8920 9200...
My vax model vrs7w wont release cleaning fluid
Sticking valve or blockage. Refer to handbook.
Aug 17, 2014 | Vacuums
Carpet cleaner vax
did it work before? if so then you could have a blockage from the outlet (where the pipe connects to the water tank which model do you have ? and was the filter present when you was working with the trigger only?
Apr 15, 2014 | Vacuums
Carpet cleaning
Carpet shampoo is popular way to clean your carpets. There are many different brands of carpet shampoo, so make sure that you follow the guidance on the label.
  1. Make up the solution as directed on the packaging. In many cases, the product will need to be diluted with water.
  2. Use just enough carpet shampoo to cover the area.
  3. Do not make the carpet too wet - not only is this a waste of detergent, but it's also going to increase drying time.
  4. Scrub on the particularly stubborn areas using a hard-bristled brush.
  5. Let the carpet dry.
  6. Vacuum the shampoo once it has dried.
Carpets and floor cleaning
May 17, 2013 | Vacuums
Vax match won't discharge solution or water
please see the videos for troubleshooting and help:
http://support.vax.co.uk/help-videos
God bless you
Jul 24, 2012 | Vacuums
How do you use vax 2000 to shampoo carpets. do not have a manual
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
Vax carpet shampooer wont release shampoo
Jun 01, 2008 | VAX Appliances Vacuums
Vacuums Logo
442 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
