Question about Royal 15MX Shredder
Royal 15MX shredder does not run at all in auto mode. Runs fine in reverse.
    New Friend:
I just had this exact problem with my shredder. I found that the LM324 IC on the circuit board was shorted out, and it tool the LM7812 regulator with it. I replace both and it's good as new.
Posted on Jan 11, 2014
  • 72 Answers
There is most likely something blocking your shred gears preventing it from running in forward motion. If you press the feed button will it engage the motor? If not, you will need to have it serviced if you cannot visibly see any blockage. Be sure to unplug this unit before attempting to clear the pathway.
Posted on Mar 13, 2011
Shredder will not operate in forward mode.
Sounds like the bin might be over full. Switch machine off. Remove top section, or open door, Empty bin. Look at shredder blades to make sure nothing is stuck in them. When sure blades are clear put back together and then switch on.
Mar 18, 2014 | Royal 15MX Shredder
How to reset royal 15mx shredder? it continues to run when put in the auto position.
I see that the unit runs when in Auto position.
First make sure you turn the machine OFF then see if there is anything in the way of the shredder that gets detected by the sensor.
That can be one reason why it keeps on running when in Auto.
To reset turn the unit OFF and unplug it from the wall outlet or power source then hold down the power button for at least 5-15 seconds then plug it back in then turn or power the unit back up.
Still make sure that there is no paper debris anywhere in the way of the sensor.
I hope this helps.
Sep 08, 2011 | Royal 15MX Shredder
My royal paper shredder is jammed. How do I unjam the shredder?
Normally try to run it in reverse while pulling the paper back out to assist the motor. If it won't even run in reverse then you will have to take it apart to manually clear the jam.
Sep 10, 2010 | Royal 15MX Shredder
Will only run in reverse mode
Most likely the pcb inside the unit..give Royal a call at 1-800-524-0799 for parts and prices.
May 13, 2010 | Royal 15MX Shredder
Royal 15MX will run in reverse. Ready light does not come on. Will not run in forward.
Probably the pcb inside ...call Royal at 1-800-524-0799 for parts.
Mar 04, 2010 | Royal 15MX Shredder
How to fix royal 15mx shredder that only runs in reverse
Only running in reverse normally indicates the pcb is gone inside machine.....give Royal a call at 1-800-524-0799 and they will advise on availability and price.
Jan 22, 2010 | Royal 15MX Shredder
Royal Orca 9512x shredder will not run. I have checked the fuse and it is good. Cleared a paper jam and still wont run forward or reverse.
If motor wont run at all then probably the pcb is blown...call Royal at 1-800-524-0799 for parts and prices.
Sep 15, 2009 | Royal 15MX Shredder
Royal 15MX Shredder Logo
306 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
