Hooking up TV to use as computer monitor. Snowy screen is all I get please help
    Master:
  • 525 Answers
Make sure your pc input is selected. Also make sure your BLUE vga inputs are connected with a vga to vga cable.
Posted on Mar 13, 2011
Samsung hdmi problems
There should a button on the monitor to switch the input. Press it until you see HDMI on your screen.
Jul 31, 2014 | Samsung T220HD LCD Monitor
Why is desktop green like theres way to much yellow hue
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 03, 2014 | Emerson LF320EM4 32" 720p 60Hz Class LED...
HP pavillion dv9000 has black horizontal lines across screen and looks like a snowy background
Sounds like the screen is going bad. Isolate the problem by plugging an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the Borrowed monitor does not show the black lines and snowy background, that proves your video card is ok and the problem is your lcd screen. If the borrowed monitor shows the same black lines ans snowy background it means your video card inside the computer has the issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 18, 2012 | HP Compaq Business Notebook nx7000
Radiation lines scroll on monitor screen
Check and jiggle (yes, that's the technical term) the monitor cable at both ends to make sure the connection is tight. If this doesn't help, borrow a cable from another computer (or a friend) that you know works, and use that to connect the monitor to the computer. If the picture is no longer snowy, you have a bad cable; buy a replacement one from any number of dealers (I recommend http://www.discountcablestore.com/, they're just about the best prices anywhere, but if you don't feel comfortable ordering online, any store with an electronics department should have one.)
If it is still snowy, try plugging your computer into a different monitor and see if the picture is still snowy. If it isn't, then your monitor has probably gone bad; check it's warranty, and consider buying a replacement.
If it is still snowy, post back here with the name of your graphics card (in Windows, this can be found by pressing the Windows key and the R key at the same time, then typing in 'dxdiag' without the quotes, hitting Enter or OK, and looking at the 'Display' tab of the window that opens. If a warning message shows up about it being run for the first time, click OK or Yes.).
Mar 01, 2011 | Samsung SyncMaster 152 (Silver) 15" LCD...
Monitor screen is snowy and has a vertical bar 2
This could be either your screen is failing or your grahpics card
Jul 04, 2010 | Sony ® VAIO® V TV-PC Series -...
Wide, snowy horizontal bars scrolling on Viewsonic VA1912WB
Changing computers doesn't help. Followed all suggestions from Viewsonic Tech Support. Problem is in monitor circuits--had to replace it.
Dec 23, 2009 | Acer AL1916W 19" LCD Monitor
I have a Dell 19" flat screen TV/Monitor that came with the computer and is my computer screen. While watching, the picture went black. We have determined that it is the TV/Monitor by hooking up another...
Try these :
1.) reinstall your operating sys .
2.) sounds like there is a short somwhere. is it under warranty?
3.) Check the plug-in for the external power pack. Mine did the same thing and it turned out to be an old and week connection at the plug... the contacts were not fully making.
Let me know if teh above are OK .. !
Mar 20, 2009 | Recoton Advent Advent Q1435A TV
I HAD TV ON. EVERYTHING WAS FINE. ALL OF A SUDDEN, IT BECAME SNOWY. LIKE THE CABLE WAS OUT. SO, I TRIED UNHOOKING DIGITAL CABLE BOX. AND HOOKING CABLE STRAIGHT TO THE TV. STILL, IT WOULD NOT GO ANY HIGHER...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} With the snowy problem; it does sound like aerial has disconnected. Try putting your finger over the aerial socket hole behind the TV while TV is on (using your self as an aerial). If snowy disappears then you have an aerial plug/wire disconnection problem.
Dec 06, 2008 | Televison & Video
Computer monitor problem
power supply is most likely going could be capacitors on the vga /inverter board also needs to be checkd out at a service location
May 01, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
